"Kotuku" wrote:
> Anwar wrote:
> > Hi
> > hope someone can give me some advice.... just recently i purchased a new
> > notebook ( Amilo Li3710 from Fujitsu) operating system is Vista...
> > when i used the the first time the internet it crashed and showed me this
> > error-message:
> > Problem signature:
> > Problem Event Name: BlueScreen
> > OS Version: 6.0.6001.2.1.0.768.3
> > Locale ID: 2057
> > Additional information about the problem:
> > BCCode: 77
> > BCP1: C000000E
> > BCP2: C000000E
> > BCP3: 00000000
> > BCP4: 0BD42000
> > OS Version: 6_0_6001
> > Service Pack: 1_0
> > Product: 768_1
> > Files that help describe the problem:
> > C:\Windows\Minidump\Mini050109-01.dmp
> > C:\Users\Anwar\AppData\Local\Temp\WER-62337-0.sysdata.xml
> > C:\Users\Anwar\AppData\Local\Temp\WER5EB2.tmp.version.txt
> > Read our privacy statement:
> > http://go.microsoft.com/fwlink/?link...3&clcid=0x0409
> > would really appreciate any advice what i can do about this problem, if they
> > are any updates i can download to fix the problem....
> > thanks >
> Ummm, This points to same error message and the prognosis is not good
> http://www.techspot.com/vb/topic98354.html
> If it does fit your problems? Seems HD failure imminent. Suggest you
> make sure Backups of data?
> Kotuku
> First of all thank you very much for the link.... was helpful....yeah lucky
i got all my data and important files on my external harddrive saved...;-)
but didnt had time to do a recovery back up for OS...will do it within the
next days when im off from work!!!
had a look on the link that you provided...
it defintly matches with my problem and there was as well a helpful tip with
a link..
just have a another question...on the link that u gave it says i should run
or download a ' Drive diagnostic utilities compendium '
.... which also gave me a listing of every major drive manufacturer and
their drive diagnostic utilities... ( in my case Fujitsu Siemens)...
Anyhow i decied first to do a extended system diagnostics run on my notebook
(which is provided from my manufacturer ' Fujitsu Siemens' and as well on my
notebook already installed) and just wanted to know isn't that the same
diagnostic ??? or are they different???
coz when i went on the link :
http://www.fel.fujitsu.com/home/drivers.asp?L=en&CID=1
i got confused which one to download coz my OS is windows vista and there
are different one for MS-DOS or windows 2000/ 98..which i think isn't the
right ones to download or am i wrong???..
was wondering if u can give me an another advice on that one....
i am still though a bit confused coz i purchased the notebook just 3days
ago and i am just wondering how it could happen that i have a failure already
with the hard drive !?!
