Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Problems with Vista Home Premium 64bit
Old 05-02-2009   #1 (permalink)
I recieved an Acer Aspire G7200 Predator (see sats below) for my 21st roughly 3 weeks ago and everything was fine for the first week, it was fast, responsive and games installed within seconds.
Since the system started installing windows updates i've had all sorts of problems. My computer has become sluggish at start up despite disabling all unnnecessary programs. It also seems to have trouble running installation disks, the process is painfully slow and the desktop freezes if you try to run anything at the same time. which was never a problem before...
Even more frustrating is that i bought a copy of Corel VideoStudio Pro X2 (completely vista compatible!) and it freezes half way through installing the installation wizard... =/ Then i get the following error code: "1670: Unable to load module K:\ISSetup.dll, Error code:999" and then the program closes...
I really hope someone can help me with this because i'm at my witts end!
Syst mod: Acer Aspire G7200 Predator
OS: Windows Vista Home Premium x64
CPU: AMD Phenom 98502 Quad-core ~ 2.5GHz
RAM: 4GB DDR II
HDD: 150GB (10kRPM), 640GB
VGA: 2x ATI Radeon HD 4950 1GB
Print spooler problems in Vista Home Premium 64bit Vista print fax & scan
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
Vista home premium 64bit Drivers
Installing Vista Home Premium 64bit OEM problems Vista installation & setup
XP Pro 32-bit to Vista Home Premium 64Bit Vista installation & setup
