howdy there
my fiance's laptop is a bit sluggish, and i've managed to find the following 3 reg errors via registry mechanic(a trial version).
is there any kinda way i can fix these probs with somethign other then registry mechanic as it's a wee bit costly at the moment? many kind thanks vista gurus!
3 reg errors, these are all indicated as "High Priority values missing or invalid":
1. HKEY_CLASSES_ROOT\CLSID\{300165D9-44B1-4C7A-AD58-4A9E7200E2E8}\LocalServer32
2. The second error is exactly the same as the first (see above error #1.)
3. HKEY_LOCAL_MACHINE\SOFTWARE\MicrosoftWindows\Databases\Windows
Many kind thanks dudes...
