| | Unexpected AC Power Loss Hello - At random times during my computers opperation, my whole computer suddenly seems to loose its AC Power. This only started occuring after installing Vista. It then has much trouble turning back on - as it keeps doing the same thing many times, until finnally it boots correctly, also showing the "safe mode" options. Can anyone please help? Thankyou, Ryan |
| | Re: Unexpected AC Power Loss If the computer is suddenly shutting down due to loss of power, with absolutely no prior warning or error indication, you have a hardware problem. It is co-incidental that it started occurring after you installed Vista. Start by checking to see if you have an over heating problem. Are all of your cooling fans clean of dust and dirt buildup, especially the CPU fan/heatsink and the power supply fan intake and exhaust areas? -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "Ryan Carmichael" <RyanCarmichael@discussions.microsoft.com> wrote in message news:14072799-9095-4324-AFB2-374A2A4DCC14@microsoft.com... > Hello - > At random times during my computers opperation, my whole computer suddenly > seems to loose its AC Power. This only started occuring after installing > Vista. It then has much trouble turning back on - as it keeps doing the > same > thing many times, until finnally it boots correctly, also showing the > "safe > mode" options. > Can anyone please help? > Thankyou, > Ryan |
| | RE: Unexpected AC Power Loss As well, depending on the age of the system/power supply...It could be in it's dying stages. Also ensure your PC is connected to a surge protector to ensure voltage spikes are not forcing the system to power itself down. "Ryan Carmichael" wrote: > Hello - > At random times during my computers opperation, my whole computer suddenly > seems to loose its AC Power. This only started occuring after installing > Vista. It then has much trouble turning back on - as it keeps doing the same > thing many times, until finnally it boots correctly, also showing the "safe > mode" options. > Can anyone please help? > Thankyou, > Ryan |
| | Re: Unexpected AC Power Loss On Wed, 18 Oct 2006 02:40:01 -0700, Ryan Carmichael <RyanCarmichael@discussions.microsoft.com> wrote: >Hello - >At random times during my computers opperation, my whole computer suddenly >seems to loose its AC Power. This only started occuring after installing >Vista. It then has much trouble turning back on - as it keeps doing the same >thing many times, until finnally it boots correctly, also showing the "safe >mode" options. >Can anyone please help? >Thankyou, >Ryan Are you plugged into a UPS? They fail poorly sometimes, with erratic switching in and out, sending a battery discharged signal to the CPU box. Got bad Power supply fan? |
| | RE: Unexpected AC Power Loss Sounds like your cpu is running to hot. When that happens, in most computers these days, it just shuts down without any kind of warning, and it will turn on again when it has cooled down a bit. After a shutdown, you turn your computer on and it turns off almost right away. Look in your bios and see how hot your cpu is. If it is running hot, open your case and see if your cpu cooler is still working and dust free. I live in spain and i see this problem a lot, it gets very hot here in the summer. Your cpu has to work harder with windows vista, in turn your cpu gets hotter. But then i can be wrong. Franky "Ryan Carmichael" wrote: > Hello - > At random times during my computers opperation, my whole computer suddenly > seems to loose its AC Power. This only started occuring after installing > Vista. It then has much trouble turning back on - as it keeps doing the same > thing many times, until finnally it boots correctly, also showing the "safe > mode" options. > Can anyone please help? > Thankyou, > Ryan |
| please help power loss during system restore | General Discussion | |||
| power loss changed network | Vista networking & sharing | |||
| Installation loss of power | Vista installation & setup | |||
| loss of internet connection and sidebar (but not 100%loss). | Vista networking & sharing | |||
| USB device unplug causes power loss | Vista hardware & devices | |||
