.zip problem
  1. #1
    Ralph Guest
    .zip problem
    The problem started with a monitor driver download from Dell.
    The instructions on the disk did not match the ones on the website.
    Now I cannot unzip anything, without continous windows opening.
    I then need to log off, or shut down to stop it.
    Is there a way to reset the Vista Ultimate unzip function?
    If I'm in the wrong group, please advise, as well.
  2. #2
    Ralph Guest
    Re: .zip problem
    Ok, silly me.
    There is no Vista unzip.
    I removed the zip program I had. - same problem.
    I went into the file association menu, and found that .zip had been
    associated with IE. - (nasty blighters)
    I downloaded another zip program, and associated that program with .zip -
    problem fixed.
    "Ralph" <aj531@xxxxxx> wrote in message
    news:ujByO4w9JHA.4944@xxxxxx
  3. #3
    Spirit Guest
    Re: .zip problem
    Actually there is however its a good idea to replace it as it is SLOW and
    has a few issues.
    http://windowshelp.microsoft.com/win...d341a1033.mspx
    ZIP File Support - Restore
    http://www.winhelponline.com/article...d-To-menu.html
    http://www.mydigitallife.info/2008/0...-cabinet-file/
    http://www.7-zip.org/
    And of course there is WinZip and WinRar
    news:uqnqxux9JHA.4948@xxxxxx
    > Ok, silly me.
    > problem fixed.
.zip problem problems?
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
fixed unable to delete email problem, now I have new problem j2 Vista mail 19 29 Mar 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
