Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Re: 32 bit or 64 bit in this situation?
Old 06-29-2009   #1 (permalink)
Al Romanosky
Does your chipset (Board) support 64 bit OS?
Applications must be specificaally written to take advantage of a 64 bit
system.. Win 64 OS will creagte teo two Program Files folders - one for 32
and one for 64 applications.
Old 06-29-2009   #2 (permalink)
Victek
> Unfortunately, my chipset supports a max of 4GB and that is what I
Quote:
> have installed. This means that both 32 and 64 bit OSs have the same
> amount of memory available, viz 3.12 GB. See MSKB 929605 for more
> info.
> Are there any performance benefits in this situation to using 64 bits
> over 32 bits (Windows and/or Linux)? I am only interested in better
> performance and nothing else like driver availability.
Since you're only seeing 3.12 GB with a 32 bit OS you would get almost a
full gig more with 64 bit. That would improve performance if you
sufficiently load the system - you would be able to run more applications
before the system would have to start using the page file. An important
issue is whether or not the BIOS supports memory mapping above the 4 GB
address space. In order for the OS to use all 4 GB for itself and
applications the memory addresses for hardware need to be moved up.
How to set up a WEP in a complex situation Browsers & Mail
Nightmare situation Vista General
Can any one seriously solve this situation? Vista General
A no-quit situation Vista General
how to compare in this situation PowerShell
