(question)a problem has caused the program to close, need help, how to disable this
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 11:44 AM
    Hi.. im using windows vista and runing a small online game server
    which sometimes crashes.. and displays the close box.. but i have a restarter.. which doesn't restart the app if i don manualy close it by pressing the close button.. is there a way to disable this close box displaying? just automaticaly close the program.. i need help very much please!
  2. #2
    Newbie
      Thread Starter
    Re: (question)a problem has caused the program to close, need help, how to disable th
    sorry for double posting.. but no one unswered .. is there realy no one who could help?
  3. #3
    Bill Daggett Guest
    Re: (question)a problem has caused the program to close, need help, how to disable this
    >who could help?
    Help with WHAT? You are using a web-based access to Usenet where your
    posts are sent to Microsoft servers. We don't see what you see.
    State your problem again, or reply to your original post and choose to
    quote that post before you reply
  4. #4
    Newbie
      Thread Starter
    you didnt understand what i asked.. i dont want you to solve the error msg which was sent to microsoft or smthn .. i disable solution center and stuff.. my question is
    HOW TO REMOVE THE NOT RESPONDING MESSAGE .. e.g. program encountered a problem and need to close.. jada jada.. why the heck should i want.. to press the close button.. for the programm to close? .. i am running a mmorpg game server which eventualy crashes.. but the auto restarter doesn't kick in .. becouse of that ridicilous not responding message .. is there a way to remove it? ..
(question)a problem has caused the program to close, need help, how to disable this problems?
A problem caused this program to stop interacting with Windows PhotoshopUser Vista General 1 06 Mar 2009
"A problem caused the program to stop working correctly..." roach_779 Gaming 2 20 Aug 2008
A problem caused the program to stop working correctly.... nizza35 Vista installation & setup 1 09 Mar 2008
Close this program or search for the right topic and close this pr Allan Vista security 0 18 Jul 2007
a problem caused the program to stop DavidH Vista General 2 28 May 2007
