Driver State Power Failure
  1. #1
    Newbie
    Vista home 64 bit
    Local Time: 09:40 PM
    Hi i need serious help. I keep getting driver state power failure at shut down. I need some help to this solution. I checked my mini dump file to see what the problem was and it said ntoskrnl.exe? How can i fix this. Im so pissed i spent 2k on a gaming computer and i get this dumb error at shut down.
  2. #2
    Guest
    Re: Driver State Power Failure
    Type verifier in Start Run and see if crash dump with verifier on gives
    extra info.
    Driver Verifier monitors kernel-mode drivers to detect illegal function
    calls or actions that might corrupt the system. It was first included in
    Windows® 2000 and is available in all later versions of Windows. Driver
    Verifier works on both the free and checked builds of Windows operating
    systems.
    For Windows Vista®, Driver Verifier was enhanced with new tests and features
    that let Driver Verifier expose more classes of typical driver bugs. Also,
    Driver Verifier is easier to use, beginning with Windows Vista. This paper
    provides a preview of Windows Driver Kit (WDK) documentation for the Driver
    Verifier enhancements in Windows Vista.
    This paper applies for these operating systems:
    Windows Server® 2008
    Windows Vista
    The current version of this paper is maintained on the Web at:
    http://www.microsoft.com/whdc/DevToo...vVerifier.mspx
    "Xth09" <guest@xxxxxx-email.com> wrote in message
    news:d9252b4824a4106e819dfdbe3ccd5125@xxxxxx-gateway.com...
    > error at shut down.
    > Xth09
  3. #3
    Newbie
    Vista home 64 bit
      Thread Starter
    im sry, i dont understand you. I never use my pc for anything else other than gaming. You will have to explain more.
  4. #4
    Guest
    Turn verifier on, then check your new mini dumps. They may have extra info.
    news:8ad572ab401429391074f61a119c4a9b@xxxxxx-gateway.com...
    > than gaming. You will have to emplain more.
    > Xth09
BLUE SCREEN - Driver Power State Failure - PLS HELP ME songryong Vista General 1 14 Mar 2010
driver power state failure mchrisokc Crashes and Debugging 13 27 Sep 2009
Driver Power State Failure.... Ninetyfourgoali Drivers 13 20 Sep 2009
Driver Power State Failure BSOD crzytenor Drivers 3 25 Jun 2009
driver power state failure skytopdesigns Vista hardware & devices 4 05 Oct 2007
