| | System Restore and Missing Links I have a one week old HP with Vista Premium x64. I have not made the system restore disks yet. Been busy sorting out software problems I have the following problems: Control panel will not open on the start menu or through explorer when I click on it. The subdirectories will open when I click on the carrot on the left of control panel in explorer. FreeCell.exe will not run. System restore will not find a restore point. It is not working properly. " The volume shadow service used by system restore is not working. For more information view the event log.(0x81000202) All the other software I have check is operating. Firefox is a little balky even without addins. Any help is appreciated. Thanks. Peter |
| | Re: System Restore and Missing Links peter wrote: Quote: > I have a one week old HP with Vista Premium x64. I have not made the > system restore disks yet. Been busy sorting out software problems > > I have the following problems: > > Control panel will not open on the start menu or through explorer when I > click on it. The subdirectories will open when I click on the carrot on > the left of control panel in explorer. > FreeCell.exe will not run. > System restore will not find a restore point. It is not working properly. > " The volume shadow service used by system restore is not working. For > more information view the event log.(0x81000202) > > All the other software I have check is operating. Firefox is a little > balky even without addins. 2. Since the system is new, restore it to factory condition. Once restored, uninstall unwanted/obsolete/trial software. If McAfee or Norton came preinstalled, replace it with Avast or Avira (free versions). Update to Service Pack 2 if necessary. If the computer misbehaves, contact HP tech support or take it back to where you bought it for immediate replacement. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | Re: System Restore and Missing Links "Malke" <malke@newsgroup> wrote in message news:ujA8c7LUKHA.4704@newsgroup Quote: > peter wrote: > Quote: >> I have a one week old HP with Vista Premium x64. I have not made the >> system restore disks yet. Been busy sorting out software problems >> >> I have the following problems: >> >> Control panel will not open on the start menu or through explorer when I >> click on it. The subdirectories will open when I click on the carrot on >> the left of control panel in explorer. >> FreeCell.exe will not run. >> System restore will not find a restore point. It is not working >> properly. >> " The volume shadow service used by system restore is not working. For >> more information view the event log.(0x81000202) >> >> All the other software I have check is operating. Firefox is a little >> balky even without addins. > 1. Make the recovery disc set *now*. > > 2. Since the system is new, restore it to factory condition. Once > restored, > uninstall unwanted/obsolete/trial software. If McAfee or Norton came > preinstalled, replace it with Avast or Avira (free versions). Update to > Service Pack 2 if necessary. If the computer misbehaves, contact HP tech > support or take it back to where you bought it for immediate replacement. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > http://www.elephantboycomputers.com/#FAQ > the hard drive first? Thanks. Peter |
| | Re: System Restore and Missing Links peter wrote: Quote: > Should I do the disks before restoring from the hard drive or restore from > the hard drive first? That way if something goes wrong with the drive you'll have them. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | Re: System Restore and Missing Links Thanks for the help. I have come up for air. Nothing ever goes as fast as projected. I think I am OK now but have not done much work for the last two days. As best I can recollect, the problem sequence went something like this. Firefox was not running smoothly and I had AVG and zonealarm installed. The same as my xp installation for about 2 years. I tried clearing them from startup and reboot. There was still avg processes running in task manager. Uninstalled them. I guess through the control panel. Then I cleaned the registry. Bad news. Peter "Malke" <malke@newsgroup> wrote in message news:uGISdFRUKHA.3428@newsgroup Quote: > peter wrote: > Quote: >> Should I do the disks before restoring from the hard drive or restore >> from >> the hard drive first? > Do them now. It will take a couple of DVDs and under an hour of your time. > That way if something goes wrong with the drive you'll have them. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > http://www.elephantboycomputers.com/#FAQ > |
| System Restore is MISSING completely from my Vista Ultimate 32bit! | General Discussion | |||
| system restore not creating system restore everyday | Vista General | |||
| System Restore points missing. | Vista General | |||
| System Restore Checkpoints Missing | Vista security | |||
| Movie Maker - Missing Photos not missing Links | Vista General | |||
