| vista x64 | Major Problem My computer is freezing about 10 seconds after being unlocked or restarted. The desktop, bottom bar and start menu all freeze but if i am able to open applications before everything freezes i can use them while the rest of the computer is still frozen. ctrl+alt+del opens the normal page and i can open task manager but that instantly freezes. The login page isnt frozen thoug because from the ctrl alt del menu i can change users and resart my computer from there but thats it. I dont know whats wrong please help!!!!!!!!!!!1 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Major Problem Hello illskillz, You might see if doing a System Restore at boot using a restore point dated before you had this problem may be able to fix it for you. Hope this helps, Shawn My computer is freezing about 10 seconds after being unlocked or restarted. The desktop, bottom bar and start menu all freeze but if i am able to open applications before everything freezes i can use them while the rest of the computer is still frozen. ctrl+alt+del opens the normal page and i can open task manager but that instantly freezes. The login page isnt frozen thoug because from the ctrl alt del menu i can change users and resart my computer from there but thats it. I dont know whats wrong please help!!!!!!!!!!!1 |
| vista x64 | Re: Major Problem Thanks, but I did that earlier with no success. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Major Problem Sounds like you may need to do a Custom install to reisntall Vista. This way all of your current files in your current installation will be place in a "C:\Windows.old" folder so you can copy the one you want back after reinstalling. ![]() |
| Major Problem, need help! | Vista General | |||
| A major problem | Live Mail | |||
| Major Problem, please help | System Security | |||
| Help need!OS problem Major | General Discussion | |||
| MAJOR Problem! Help! | General Discussion | |||
