Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Lightscribe problems
Old 3 Weeks Ago   #1 (permalink)
Patricia anne
Hi, I am experiencing lightscribe problems, I have recently had a new hard
drive fitted by H.P and when the laptop came back it was perfect for a week.
Then when I go to label a disc the lightsribe program just freezes and stops
working
I have tried uninstalling the program and reinstalling it but it is still
the same.
I have also tried another labelling program that is on my laptop but this
does the same thing. I need some help please
my hp g70 macine is running vista home premium.
regards Pat
p.s. everything else seems to work, also the drive says that it is working
o.k.
Old 3 Weeks Ago   #2 (permalink)
SC Tom
Re: Lightscribe problems
"Patricia anne" <Patriciaanne@newsgroup> wrote in message
news:810BCA1B-6F6E-40EF-8970-B1974B9705D3@newsgroup
> week.
> stops
> working
> the same.
> regards Pat
> o.k.
Can you still create CD's with the drive? If so, my guess is the Lightscribe
drive is going belly-up for the labeling part.
Have you tried the software from Lightscribe:
http://www.lightscribe.com/DownloadS...ows/index.aspx
I gave up on the other labeling programs and use the Lightscribe Template
Labeler. There are plenty of pre-made templates available, and even those
can be edited.
SC Tom
Old 3 Weeks Ago   #3 (permalink)
Patricia anne
Hi Tom,
Thanks for your reply, and yes I have burnt cds and dvds with no trouble. I
think your guess is probably right, and the trouble lies with the drive
itself with labelling. Also yes I have tried the lightscribe programmes,
installing, and then uninstalling a couple of times, but it did not work
whereas when the machine came back from being repaired it did for about a
week.
Thing is why did HP not pick this up? It was within the faults I had
reported to them.
regards Pat
> > week.
> > stops
> > working
> > the same.
> > regards Pat
> > o.k.
> can be edited.
> SC Tom
Old 3 Weeks Ago   #4 (permalink)
SC Tom
You'd have to ask them that question. If the laptop is still under warranty,
I'd send it back, even though that's always a PITA. If it's out of warranty,
and you really want/need the Lightscribe capability, check on the price of a
direct replacement (most are not that hard to replace), or a third-party
external one like LaCie. We had one where I worked that worked very well,
but the thing weighed a ton, making it a little impractical for travel.
SC Tom
news:464A93A9-35EA-4779-9096-CC9353145403@newsgroup
Quote:
> Hi Tom,
> I
> week.
> reported to them.
> regards Pat
>> > hard
>> > week.
>> > stops
>> > working
>> > still
>> > the same.
>> > this
>> > regards Pat
>> > working
>> > o.k.
>> Lightscribe
>> can be edited.
>> SC Tom
Old 2 Weeks Ago   #5 (permalink)
SC Tom
You must have Charter like I do LOL!
Contacting HP is the best idea with it still being under warranty. That way,
if anything goes wrong with it later, you'll have an audit trail to possibly
get it fixed for free.
SC Tom
news:4DDB2606-0D19-402E-9890-FC3BF4EBA8CD@newsgroup
Quote:
> Hi Tom, So sorry not replying before this, my broadband has been off for
> over
> a week
> Anyway, yes my laptop is still under warranty so I will get in touch with
> HP
> about it kind regards Pat
> "SC Tom" wrote:
>> warranty,
>> warranty,
>> of a
>> SC Tom
Quote:
>> > Hi Tom,
>> > trouble.
>> > I
>> > programmes,
>> > work
>> > a
>> > week.
>> > reported to them.
>> > regards Pat
>> >> message
>> >> > new
>> >> > hard
>> >> > a
>> >> > week.
>> >> > and
>> >> > stops
>> >> > working
>> >> > still
>> >> > the same.
>> >> > this
>> >> > regards Pat
>> >> > working
>> >> > o.k.
>> >> Lightscribe
>> >> Template
>> >> those
>> >> can be edited.
>> >> SC Tom
Old 1 Week Ago   #6 (permalink)
Patricia anne
Cheers Tom,
Thank you so much for your friendly advice I do appreciate it.
kind regards Pat
> SC Tom
> > over
> > a week
> > HP
> > "SC Tom" wrote:
> >> warranty,
> >> warranty,
> >> of a
> >> SC Tom
> >> > Hi Tom,
> >> > trouble.
> >> > I
> >> > programmes,
> >> > work
> >> > a
> >> > week.
> >> > reported to them.
> >> > regards Pat
> >> >> message
> >> >> > new
> >> >> > hard
> >> >> > a
> >> >> > week.
> >> >> > and
> >> >> > stops
> >> >> > working
> >> >> > still
> >> >> > the same.
> >> >> > this
> >> >> > regards Pat
> >> >> > working
> >> >> > o.k.
> >> >> Lightscribe
> >> >> Template
> >> >> those
> >> >> can be edited.
> >> >> SC Tom
Labelflash & Lightscribe Vista General
Lightscribe burner. General Discussion
lightscribe Vista hardware & devices
Lightscribe Vista hardware & devices
Lightscribe??? Vista General
