Problems after installing Office Technical Refresh
  1. #1
    Dr. Edison Guest
    Hello, After installing the TR, I'm having some issues. For example, any
    property window is longer and narrower with a font so small, I almost need a
    magnifying glass to see it. Excel documents are also too narrow, I have to
    adjust the column width in order to make them usable. This is true even when
    using a new MS template. The font size in many apps has also shrunk to ant
    size.
    Would anyone know how to remedy this?
    I've tried uninstalling and reinstalling Office 2007 and the unwanted
    changes are still present.
    Thanks,
    Edison
  2. #2
    retired fire Guest
    RE: Problems after installing Office Technical Refresh
    Try restore feature to revert back to a date just prior to the installation
    of TR...
    > size.
    > Thanks,
    > Edison
  3. #3
    Dr. Edison Guest
    That works. I tried installing TR again, still have the same issue. Any idea
    how to fix the fonts and width issue?
    > of TR...
    > > size.
    > > Thanks,
    > > Edison
Problems after installing Office Technical Refresh problems?
Office 2010 Technical Preview screenshots Slimy Vista News 5 28 May 2009
Problems Installing Office 2007 SP1! ThÉoPatrizi Microsoft Office 3 16 Aug 2008
OT: Office 2007 beta technical refresh DJ Bjorklund Vista General 3 05 Oct 2006
Bring out a RC1 technical refresh next month !! =?Utf-8?B?UmVNZUU=?= Vista General 8 14 Sep 2006
Ms Office 2007 Technical Refresh =?Utf-8?B?T2JpYWxvcg==?= Vista General 1 14 Sep 2006
