Finger pointing device problem
  1. #1
    Adam Guest
    I reciently purchased a laptop with good specs in hope it would handle more
    multitasking. Every so often the laptop forgets about the finger pointing
    device (the thing that replaces the mouse) and that arrow becomes perminantly
    stuck. It sometimes happens with the keyboard also, sometimes both at once.
    It's like it crashes but everything else is still working.
    Is this normal?!
    2Ghz Intel Centrino Core2Duo 800Mhz Fast Bus, 3GB DDR3, 320 GB
    Adam
  2. #2
    DL Guest
    Re: Finger pointing device problem
    Normal, no
    Did you make the mistake of using MSUpdate for drivers?
    And what does Event Viewer show?
    "Adam" <Adam@newsgroup> wrote in message
    news:EAB99B30-2B42-4C07-B221-17AFA44776F8@newsgroup
    > perminantly
    > once.
    > Is this normal?!
    > Adam
  3. #3
    GSalisbury Guest
    > more
    > perminantly
    > once.
    > Is this normal?!
    > Adam
    Did you consider taking the "reciently purchased a laptop " back to where
    you got it?
Finger pointing device problem problems?
Re: synaptics pointing device kristinstokes Vista General 0 03 May 2009
Re: alps pointing device Malke Vista hardware & devices 0 23 Mar 2009
Synaptics Pointing Device ChrisC Vista General 3 25 Feb 2009
alps pointing device Charles Davidson General Discussion 0 09 Mar 2008
Synaptics Pointing Device Karl Vista General 8 29 Jan 2008
