Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Task Scheduler Problems
Old 12-14-2006   #1 (permalink)
Mark B
I setup seveal tasks in Task Scheduler (Wnidows Vista RC1) to run simple .cmd
files that are located on my desktop.
The files run fine when they are double clicked, but the do not seem to want
to run when they are scheduled. I keep getting 0x4 errors.
Also, I cannot seem to get the files to be viewed while running, they only
seem to run in the backgruond.
Does anyone have any suggestions?
Thanks, Mark
Old 12-14-2006   #2 (permalink)
mikeyhsd
Re: Task Scheduler Problems
do not know what the 0x4 error is.
my scheduled tasks run ok,.
double check the different setup options in the task scheduler for each.
do they require admin privileges to run. there are separate boxes for different settings.
mikeyhsd@sport.rr.com
"Mark B" <MarkB@discussions.microsoft.com> wrote in message news:E1C31E5C-A6AC-4AF7-9655-AB1F9354F394@microsoft.com...
Thanks, Mark
Task Scheduler Compatibility module task status update failed General Discussion
Task Scheduler Error-task image corrupt or has been tampered with User_Feed_Synchroni General Discussion
Task Scheduler: Create task to open webpage? Vista General
Schedule a task with Vista task Scheduler wakes up computer and mo Vista General
Task scheduler returns an error : the task image is corrupt ortamp Vista performance & maintenance
