Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - Monitoring the CPU temperature
Old 12-26-2006   #1 (permalink)
JuanP
Guest
How do I monitor the CPU temperature in Windows Vista? There's no CPU
temperature indicator in task manager->performance.
Regards
Old 12-27-2006   #2 (permalink)
Rick Rogers
Guest
Re: Monitoring the CPU temperature
Hi Juan,
That sort of functionality is not provided by the OS, it's provided by a
utility from the maker of the motherboard. Check with them for a
Vista-compatible software set designed for this. As this type of software
uses device drivers, it is essential that it be Vista compatible or it will
likely fail.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"JuanP" <JuanP@discussions.microsoft.com> wrote in message
news2A651F5-150D-4C81-88CC-205B640B9D6D@microsoft.com...
> Hi,
> Regards
Old 12-28-2006   #3 (permalink)
William Haines
Guest
I use Speedfan to Monitor the Temps of my Motherboard/CPU.
"Rick Rogers" wrote:
> Hi Juan,
> likely fail.
> Best of Luck,
> > Hi,
> > Regards
Old 12-28-2006   #4 (permalink)
Dustin
Guest
re:Monitoring the CPU temperature
I second Speedfan (http://www.almico.com/speedfan.php). It works
great, and has a hard drive monitor, temp monitor, fan control, etc.
CPU Temperature Vista General
CPU temperature gadget Vista performance & maintenance
Temperature Software Software
Temperature Monitors Vista General
Fan and Temperature Monitoring program Vista on for Intel iMAC Vista installation & setup
