Power Options: Max CPU at 50%
  1. #1
    Nigel Molesworth Guest
    I've just noticed that in Control Panel | Power Options the default
    "Balanced" plan has the Maximum processor state at 50% (see Change
    Advanced power settings | Processor Power management)
    The Resource Monitor shows that it really means it!
    Nigel M
  2. #2
    mikeyhsd Guest
    Re: Power Options: Max CPU at 50%
    on MINE its Power Saver that restricts the CPU to 50%. Balanced is still it 100% but it does allow Cool & Quiet to throttle down the CPU when full power is not needed.
    mikeyhsd@sport.rr.com
    "Nigel Molesworth" <reply@thegroup-myemailisinvalid.com> wrote in message news:6k4kp2thie0hukrs4i85omhui41nkscsrj@4ax.com...
    Nigel M
Power Options: Max CPU at 50% problems?
Useful tool for power enthusiasts on the go (advanced power options) VaguelyRapt General Discussion 4 23 Jul 2012
Solved Power Options Corrupt (power plan unavailable) Domsy General Discussion 27 04 Mar 2010
Solved Power Options fertedds General Discussion 7 08 May 2009
Power Management/Power Options in Vista MarkR Vista General 4 29 Aug 2008
Power Options one Vista account administration 0 16 Sep 2006
