Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Alter (auto) Power settings when plugged in or on Battery Power?
Old 02-12-2007   #1 (permalink)
Duneed
I'm running a laptop and would love for the power settings to automatically
change from high performance when plugged in to Ballanced or Power Saver when
running on Batteries. Does the system do this....?
Old 03-12-2009   #2 (permalink)
Vista x64 bit
Re: Alter (auto) Power settings when plugged in or on Battery Power?
What I just did about five seconds ago was reset the power saver option to default, then set the computer on high performance before unplugging it to make sure it worked. sure enough, the battery performance changed when I both unplugged it and plugged it back in. I hope this helps!
Vista power settings - power button functionality Vista installation & setup
A.c power and battery power Vista hardware & devices
should i use battery or mains power? Vista General
Battery Power Vista General
Battery power-RC2 Vista General
