Problem Scrolling - Very Jerky and Slow
  1.    14 Feb 2007 #1
    Cal Bears Go Guest
    I did an upgrade install of Vista Ultimate over XP Media Center. I had
    several issues, but the most troublesome is with my mouse. I can no longer
    scroll easily. On webpages, in Word, in Excel, in Notepad, when I attempt to
    scroll down it seems to hang, then jumps forward. The side bar also is very
    jerky and jumpy. I have a Logitech MX laser 1000. I've uninstalled the
    software and reinstalled 3 times (they have new Vista software) to no avail.
    I've now uninstalled it and am running it in embedded mode...no luck. I
    tried using other mice...no luck. I've got 3 gigs of RAM and a 2.7 gighz
    processor. My rating is 3.7, so it shouldn't be a hardware issue, but it
    feels like it is...it's as if there are numerous very resource intensive
    applications running and bogging it down (there aren't).
    I called Microsoft and talked to someone in India that was no help whatsoever.
    My Microsoft keyboard is also acting funny. When I tab or use the arrow,
    the tab seems to lock and it darts from cell to cell until I hit the keyboard.
    My computer is almost unusable at this point. I never, ever had a problem
    with XP. Any help would be greatly appreciated.
  2.    27 Mar 2007 #2
    Warkworth Guest
    RE: Problem Scrolling - Very Jerky and Slow
    Having the same difficulties...let me know if you solve the problem of jerky
    scroll bar
    Judy
  3.    24 Apr 2007 #3
    Richard Guest
    > scroll bar
    > Judy
  4.    24 Apr 2007 #4
    Mark Maylon Guest
    Re: Problem Scrolling - Very Jerky and Slow
    That my friend sounds like a display driver problem . I suggest you update
    to the newest drivers availible for your machine. If you can post your pc's
    specs we can tell you which to get or further assist in this problem.
    "Richard" <Richard@discussions.microsoft.com> wrote in message
    newsDB9CE23-5B44-41F9-845D-9BF6C881C434@microsoft.com...
    >> jerky
    >> scroll bar
    >> Judy
    >> > longer
    >> > attempt to
    >> > very
    >> > the
    >> > avail.
    >> > I
    >> > gighz
    >> > it
    >> > intensive
    >> > whatsoever.
    >> > arrow,
    >> > keyboard.
    >> > problem
  5.    24 Apr 2007 #5
    mikeyhsd Guest
    try reversing the box in IE properties option for SMOOTH scroll. if checked, uncheck it or other way around.
    might also check for newer display drivers.
    mikeyhsd@comcast.net
    "Richard" <Richard@discussions.microsoft.com> wrote in message newsDB9CE23-5B44-41F9-845D-9BF6C881C434@microsoft.com...
    > scroll bar
    > Judy
  6.    25 Apr 2007 #6
    Local Time: 18:25
    I also have this problem. I have a GeForce 660GT, and I'm using the latest drivers from nvidia (ForceWare 158.18 for vista 64).
    The problem gets even worse if I do the "press the wheel down, drag mouse" scroll.
  7.    26 Apr 2007 #7
    Warkworth Guest
    Scrolling problem solved - installed the HP mouse that came with the computer
    instead of the optical mouse; however, just installed the Logitech cordless
    click optical mouse and no problem with this mouse either. Hope this helps!
    Good luck!
    Previously went to logitech website to download updates for the type of
    mouse I had...didn't work...but advised to use Hp mouse.
    Judy
    > >> jerky
    > >> scroll bar
    > >> Judy
    > >> > longer
    > >> > attempt to
    > >> > very
    > >> > the
    > >> > avail.
    > >> > I
    > >> > gighz
    > >> > it
    > >> > intensive
    > >> > whatsoever.
    > >> > arrow,
    > >> > keyboard.
    > >> > problem
Help Slow non responsive scrolling since update
I have vista business, 32g bit, lenovo laptop but with external mouse. In the last few days since a few updates happened suddenly my scrolling is...
Windows Updates
Weird scrolling problem with folders
I am having a really weird problem with my storage folders and scrolling to the bottom folder in the list. At the bottom of my email account list (...
Live Mail
Scrolling problem
This one is on a laptop (using vista home premium),when browsing,on IE,using the up/down scrollbar when I move the cursor from the bar the bar...
Software
RE: presenter mouse slow and jerky in vpc
Friggin' crap !!! Hardware acceleration works !!! Set it to Max !!! Thanks a mil dudes !!! On your desktop Right Click --> Properties Settings...
Virtual PC
I had a jerky mouse issue with VPC 2007 running on Xp SP2. I fixed it by installing XP SP3 and rebooted. The install site now says Xp SP3 is required...
Virtual PC
Slow scrolling in Internet Explorer
Scrolling is slow on some websites in IE. It seems as if it was rendered without hardware acceleration. Some other pages scroll fine. (I already...
Vista networking & sharing
Vertical scrolling...jumps rather than smooth scrolling - Excel 20
I am on Office 2007 / Windows Vista and use a Microsoft Wireless Optical Mouse 2.0. I have the latest version of Intellpoint 6.1. In Excel only,...
Vista hardware & devices
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
