How to prevent Ready Boost drive from appearing after "wake up"?
  1. #1
    acook Guest
    I’m using a Lexar SD in my media card reader for Ready Boost. It works fine
    but is there any way to stop the drive from opening after “wake up” without
    turning off autoplay?
  2. #2
    Ronnie Vernon MVP Guest
    Re: How to prevent Ready Boost drive from appearing after "wake up"?
    Just turn off the AutoPlay for the drive you are using for the readyBoost.
    Ronnie Vernon
    Microsoft MVP
    Windows Shell/User
    "acook" <acook@discussions.microsoft.com> wrote in message
    news:49DEB763-EC7E-4DF2-9093-279AE0F33778@microsoft.com...
    > fine
    > without
  3. #3
    acook Guest
    How? In "my" Autoplay window there is a section called: Devices :and Devices
    that you connect to your computer will be listed here.
    There is no list. Nothing!
    > Ronnie Vernon
    > Microsoft MVP
    > Windows Shell/User
    > > fine
    > > without
How to prevent Ready Boost drive from appearing after "wake up"? problems?
External Hard Drive doesn't show up in "my computer" but does in "device manager" bp4131017 General Discussion 15 02 Aug 2011
Ready Boost Flash Drive 4 gb from 8 gb Drive Joel Vista hardware & devices 20 10 Feb 2009
Files not appearing in "Recently Changed" folder tammylc Vista file management 0 22 Apr 2008
How to prevent that the lower part of the characters <g, j, p, q, y> are "cut off" at the four top lines <From:, Date:, To:, Subject:>?? Philippe - Swiss Vista mail 29 18 Apr 2008
How do I stop "Microsoft At Home" etc feeds appearing in my Outlook 2007 In Folder John Monahan Vista General 2 03 Mar 2007
