Defrag does not work
  1.    15 Feb 2007 #1
    ayejay0601 Guest
    When I go to Defragment drive, it shows the calendar screen. But if I click
    on "defrag now", it just hangs. Any thoughts?
  2.    16 Feb 2007 #2
    Richard Urban Guest
    Re: Defrag does not work
    There IS no display. The computer defrags in the background. After you press
    the "defragment now" button you can close the window. Defrag will run until
    it has completed.
    Regards,
    Richard Urban
    Quote from George Ankner:
    If you knew as much as you think you know,
    You would realize that you don't know what you thought you knew!
    "ayejay0601" <ayejay0601@discussions.microsoft.com> wrote in message
    news:B934547F-2CB4-4E44-9300-6BC3324B9690@microsoft.com...
    > click
  3.    16 Feb 2007 #3
    Victoria House [MSFT] Guest
    If the blue circle is "spinning" it is defragging when you click defragment
    now.
    You can close the Defrag GUI and defrag will continue until it finishes or
    you click "cancel defragmentation " (the defragment now button changes to
    this).
    If you want proof that its running, use taskmgr and display processes from
    all users. Look for defrag.exe and dfrgntfs or dfrgfat.
    -Victoria
    > click
  4.    17 Feb 2007 #4
    ayejay0601 Guest
    Ok, I officially feel stupid.
    I guess it is defragmenting in the background. I was expecting to see a
    screen that showed a graphic of the HD and green and red areas where it was
    defraging. To be honest, that was a nice feature...even for amateurs. It
    helps us amateurs get an idea of what is going on. Well..my 2 cents, but
    pass that info on to the people who make decisions will you? Thanks.
    > now.
    > this).
    > -Victoria
    > > click
  5.    17 Feb 2007 #5
    Rock Guest
    > was
    >> defragment
    >> now.
    >> or
    >> this).
    >> from
    >> -Victoria
    >> > click
    This has been discussed extensively. Do some searching on defrag in these
    newsgroups to see some of the posts. There is nothing to pass on. The GUI
    was removed for one thing because it was not very accurate. For another it
    has been designed to be run in the background, with the default time for
    running set to be when the computer is not normally used so it is handled
    without the user having to spend any effort on it.
    If you want to see the colored blocks shake and move purchase one of the 3rd
    party defragmenter tools such as Raxco Perfect Disk or Diskeeper, but there
    are many better ways to spend your money.
    Rock [MS-MVP User/Shell]
  6.    10 Feb 2008 #6
    Jayceerice Guest
    On 2/16/2007 11:26 AM PSTin microsoft.public.windows.vista.performance_
    maintenance, you responded "If the blue circle is "spinning" it is
    defragging..." per copy below. Sorry to ? your response so late but I've only
    been using Windows Vista Home Premium, 6.0.6000.16386
    (vista_rtm.061101-2205), since 8/2007, on my 1st laptop, with an NTFS file
    structure. I've have considerable problems w/hang-ups since December so I was
    browsing for others' answers. I've used Windows since the 1st one and worked
    up thru most of the Windows OSes on a PC, primarily for home use & only with
    FATS, previously.
    I've tried many times to defrag with VISTA, from Tools in Properties on my
    main drive, only after Error-Checking & restarting, & tried to watch
    everything happening, but have never noticed any "blue circle ... "spinning",
    "Calendar" or any other signs some people have mentioned this Discussion
    Group. From prior practice, after requesting the defrag, as nothing seemed to
    be happening, I always restarted, watched the screen and was surprised to see
    no mention of defrag. I thought I'd have to start over, wiping my hard drive
    & reloading Vista, etc. Finally, I checked DisKeeper after a restart & saw
    the % free increased dramatically.
    Please tell me where I should see the "blue circle ... "spinning" or if I'm
    asking the wrong ?.
    Jaycee Rice
    > now.
    > this).
    > -Victoria
defrag does not work
We have 2 Toshiba portables with vista home premium. One is fine. The defrag function on the other does not work correctly. I try to set the...
Vista General
Defrag will not work
I tried to defrag my PC after it had come back from repair shop and I got this message: MMC cannot open the file C:\WINDOWS\system32\dfrg.msc This...
.NET General
O&O Defrag doesnt work
I installed o&o defrag x64 but the program's service which is /system32/oodag.exe didnt work. I tried to reinstall or start the service manually...
Software
how long defrag work it???
hello. i wonder me about defragment! why need to long for defragment my pc?? i have windows vista home basic. why need it long time! can somebody...
Vista hardware & devices
RAID and defrag does not work
I have recently ugraded XP to Vista Business. I have a RAID-1 with Silicon Raid drivers. The computer works fine as it used to but I find that the...
Disk Defrag Doesnt work.......
So, im trying to once again run disk defrag. It hasnt worked in a couple weeks. What happens is i start it up, it runs the "anailzing disk" part and...
Does Vista B2 defrag work?
Okay, I've heard here and elsewhere that it doesn't work and I'm curious. The claim its not working is to defrag in Vista and then use a defrag in...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
