Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
RB
Vista - Problem running MyExposé...
02-18-2007   #1
n00k
Is it possible to run this on Vista Home Premium 64bit? I can't get it
to run at all!
02-19-2007   #2
Malke
Re: Problem running MyExposé...
> to run at all!
Since MyExpose is apparently a third-party program, you should check
with its tech support. The "flip 3D" natively available in Aero (and no,
I don't know whether it is supported in 64-bit because I don't have a
64-bit system) is MS's copy of the real Expose. You might want to try it.
Or perhaps your video card doesn't support Aero? Are you using the
latest 64-bit drivers from your video card maker?
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
02-19-2007   #3
n00k
Aero and Flip3D run fine, it's just this MyExposé program.
On Mon, 19 Feb 2007 06:50:52 -0800, Malke <notreally@invalid.invalid>
wrote:
>> to run at all!
>Malke
02-19-2007   #4
Malke
Then you should contact them because this isn't part of Windows Vista.
Malke
"Don't Panic!"
RB
Similar Threads for: Problem running MyExposé...
Problem running IMVU Gaming
Problem with running IE8 Network & Sharing
Problem running games Gaming
Problem running games Vista General
Problem running games Vista Games
