Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - power options
Old 02-19-2007   #1 (permalink)
SCHSCH
power options
My system won't use power options--ie wont sleep or turn off monitor even
though I have it set to through the control panel
Old 02-20-2007   #2 (permalink)
jen not techy
RE: power options
Have a look at the answer i got from rander in vista screensaver wont start
etc it worked for me
jen not techy
Solved Power Options Corrupt (power plan unavailable) General Discussion
Useful tool for power enthusiasts on the go (advanced power options) General Discussion
Power Management/Power Options in Vista Vista General
Power Options General Discussion
Power Options: Max CPU at 50% Vista performance & maintenance
