Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Shutdown freeze caused by wireless USB adapter- any reg tweaks 2fo
Old 03-13-2007   #1 (permalink)
mikeclem
My Linksys wireless B USB adapter 2.6 v.4.0 updated driver is causing a
freeze in the shutdown process with Vista Ultimate 32bit. If I unplug the
adapter prior to shutdown all is well. I've tried 3 different shutdown apps
but none solve the problem. Is there a Vista tweak (perhaps a reg timeout
adjustment) which might sort this out?
Old 03-20-2007   #2 (permalink)
Has there been any info. from Linksys as to when they plan on releasing a driver for Wireless-G USB adapter for Vista x64?
Old 05-21-2007   #3 (permalink)
Robert
RE: Shutdown freeze caused by wireless USB adapter- any reg tweaks 2fo
I have a Linksys wireless N WRT300N and it is doing the same thing. If I
unplug it before shutdown it will shutdown. Really a pain in the you know
what. I contacted Linksys and they say that it is not their problem. It is
Microsoft Vista. Not sure what to do. It doesn't seem Microsoft is really
addressing this issue.
I can't shutdown my computer when msn freeze Live Messenger
problem with blue screen caused by ethernet adapter or other cause Vista hardware & devices
RT61 wireless adapter probable cause of freeze Network & Sharing
Vista SP1 caused my PC to freeze Windows Updates
Dataman infrared adapter caused Windows Vista to crash Vista hardware & devices
