| | The product ID did not match the product selected Trying to get through with an email to MS with problems on Vista Home P. Get the "The product ID did not match the product selected" on all options selected. Where are you supposed to go from there, MS leaves you hanging? New Toshiba Computer with Vista pre installed and verified. Vista problems: Will not hiberate, just crashes Restart hangs sometimes Fast find stops working at startup Very slow startup and extemely slow shutdown (hangs most of the time) Control panel loads extremely slowly Not fast at all for a new computer How is Vista better than Windows 98, I don't see it? |
| | Re: The product ID did not match the product selected If you have an OEM vista installation then the OEM (Toshiba) provides support, not Microsoft. Check here for possible useful information on system problems Control Panel System and Maintenance Performance Information and tools Advanced tools (in left pane) at the top may be performance issues that the system can detect, otherwise look around here for problems. Michael "Dave T" <DaveT@discussions.microsoft.com> wrote in message news:4BA18261-1DCE-4D8B-93D8-8280D0610827@microsoft.com... > Trying to get through with an email to MS with problems on Vista Home P. > Get > the "The product ID did not match the product selected" on all options > selected. Where are you supposed to go from there, MS leaves you hanging? > New Toshiba Computer with Vista pre installed and verified. Vista > problems: > Will not hiberate, just crashes > Restart hangs sometimes > Fast find stops working at startup > Very slow startup and extemely slow shutdown (hangs most of the time) > Control panel loads extremely slowly > Not fast at all for a new computer > > How is Vista better than Windows 98, I don't see it? > > |
| | Re: The product ID did not match the product selected System specs, please? Maybe you bought an anemic computer. Vista's working fine for me. "Dave T" <DaveT@discussions.microsoft.com> wrote in message news:4BA18261-> Not fast at all for a new computer > > How is Vista better than Windows 98, I don't see it? > |
| | Re: The product ID did not match the product selected Since you purchased a system with Vista pre-installed, it's likely that you have an OEM version. All support for this version of Vista is the responsibility of the PC manufacturer. Your product ID will show an OEM version. A new system definitely should not be exhibiting this many problems, right out of the box. -- Ronnie Vernon Microsoft MVP Windows Shell/User "Dave T" <DaveT@discussions.microsoft.com> wrote in message news:4BA18261-1DCE-4D8B-93D8-8280D0610827@microsoft.com... > Trying to get through with an email to MS with problems on Vista Home P. > Get > the "The product ID did not match the product selected" on all options > selected. Where are you supposed to go from there, MS leaves you hanging? > New Toshiba Computer with Vista pre installed and verified. Vista > problems: > Will not hiberate, just crashes > Restart hangs sometimes > Fast find stops working at startup > Very slow startup and extemely slow shutdown (hangs most of the time) > Control panel loads extremely slowly > Not fast at all for a new computer > > How is Vista better than Windows 98, I don't see it? > > |
| | Re: The product ID did not match the product selected Thanks all. I assumed Microsoft supported Microsoft programs. Not sure how I am supposed to know this. Computer is an A105 4397 with the latest updates and drivers. "Ronnie Vernon MVP" wrote: > Since you purchased a system with Vista pre-installed, it's likely that you > have an OEM version. All support for this version of Vista is the > responsibility of the PC manufacturer. Your product ID will show an OEM > version. > > A new system definitely should not be exhibiting this many problems, right > out of the box. > > -- > > Ronnie Vernon > Microsoft MVP > Windows Shell/User > > > "Dave T" <DaveT@discussions.microsoft.com> wrote in message > news:4BA18261-1DCE-4D8B-93D8-8280D0610827@microsoft.com... > > Trying to get through with an email to MS with problems on Vista Home P. > > Get > > the "The product ID did not match the product selected" on all options > > selected. Where are you supposed to go from there, MS leaves you hanging? > > New Toshiba Computer with Vista pre installed and verified. Vista > > problems: > > Will not hiberate, just crashes > > Restart hangs sometimes > > Fast find stops working at startup > > Very slow startup and extemely slow shutdown (hangs most of the time) > > Control panel loads extremely slowly > > Not fast at all for a new computer > > > > How is Vista better than Windows 98, I don't see it? > > > > > |
| | #6 (permalink) |
| | Re: The product ID did not match the product selected Dave In reality, your options for help with any Windows Operating System are endless. There is an entire industry out there based on helping users and most of this help is completely free of charge. One of the best are these newsgroups. There are many knowledgeable people here who voluntarily give their time to help users. There are also website forums where you can get expert, personal, one-on-one help for any question about any version of Windows or even help with non-Microsoft products including hardware, regardless of the manufacturer. Many of the volunteers on these forums are Microsoft trained technicians. These forums require free registration. Here is a recommended list. AumHa Forums: http://forum.aumha.org/index.htm Computer Haven Forum: http://www.computerhaven.info/forum/ Just go there, register, select an appropriate forum and post information about whatever problem you are experiencing. -- Ronnie Vernon Microsoft MVP Windows Shell/User "Dave T" <DaveT@discussions.microsoft.com> wrote in message news:8ADE9732-28F1-4989-83B2-8353A3C979E7@microsoft.com... > Thanks all. I assumed Microsoft supported Microsoft programs. Not sure > how > I am supposed to know this. Computer is an A105 4397 with the latest > updates > and drivers. > > > > "Ronnie Vernon MVP" wrote: > >> Since you purchased a system with Vista pre-installed, it's likely that >> you >> have an OEM version. All support for this version of Vista is the >> responsibility of the PC manufacturer. Your product ID will show an OEM >> version. >> >> A new system definitely should not be exhibiting this many problems, >> right >> out of the box. >> >> -- >> >> Ronnie Vernon >> Microsoft MVP >> Windows Shell/User >> >> >> "Dave T" <DaveT@discussions.microsoft.com> wrote in message >> news:4BA18261-1DCE-4D8B-93D8-8280D0610827@microsoft.com... >> > Trying to get through with an email to MS with problems on Vista Home >> > P. >> > Get >> > the "The product ID did not match the product selected" on all options >> > selected. Where are you supposed to go from there, MS leaves you >> > hanging? >> > New Toshiba Computer with Vista pre installed and verified. Vista >> > problems: >> > Will not hiberate, just crashes >> > Restart hangs sometimes >> > Fast find stops working at startup >> > Very slow startup and extemely slow shutdown (hangs most of the time) >> > Control panel loads extremely slowly >> > Not fast at all for a new computer >> > >> > How is Vista better than Windows 98, I don't see it? >> > >> > >> |
| Product key does not match... | Vista installation & setup | |||
| Product Activation Successfull using my Beta 2 CPP Product Key. | Vista General | |||
| Incorrect Product Key on my Official Microsoft Product Key Sheet | Vista installation & setup | |||
