Vista Forums
Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista system file corruption and sfc problem
Thread Tools Display Modes
Old 05-13-2007   #21 (permalink)
Rock
Guest
Posts: n/a
Re: Vista system file corruption and sfc problem
"nweissma" wrote
> are you saying that a vista (home premium) repair install obviates a
> backup?
> i have not tried a repair install but i need one - or so i'm told - and
> going
> through a dry one, i was prompted to backup my personal files.
<snip>
I'm not sure where you got that idea. One should always have a full and
complete backup. That is a given with computers.
Rock [MS-MVP User/Shell]
Old 05-15-2008   #22 (permalink)
skitrees
Guest
Posts: n/a
Perhaps I missed it somewhere in the listings above, but were you ever
able to successfully run sfc? Is it possible that the log file you see
is just an old file?
When I received the "Windows Resource Protection could not..." error, I
was trying to run sfc from the Vista boot disk command prompt. In case
it helps (or might help someone else with the same problem) - I was
able to launch it by using the following switches:
sfc /OFFBOOTDIR=c:\ /OFFWINDIR=c:\windows
(of course, you'd have to substitute the correct drive and paths if you
installed anywhere other than c:\windows). In my case, this allowed sfc
to run without the "Windows Resource Protection could not..." error.
Anyway - I apologize if this has already been answered or gone over; I
just got lost in some of the postings.
Happy Keystrokes and Footsteps!
skitrees
skitrees's Profile: http://forums.techarena.in/member.php?userid=49426
View this thread: http://forums.techarena.in/showthread.php?t=720382
Display Modes
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
