br>
Thread Tools | Display Modes |
#21 | ||
Guest
Posts: n/a
"nweissma" wrote
> are you saying that a vista (home premium) repair install obviates a > backup? > i have not tried a repair install but i need one - or so i'm told - and > going > through a dry one, i was prompted to backup my personal files. <snip> I'm not sure where you got that idea. One should always have a full and complete backup. That is a given with computers. -- Rock [MS-MVP User/Shell] |
#22 | ||
Guest
Posts: n/a
Perhaps I missed it somewhere in the listings above, but were you ever able to successfully run sfc? Is it possible that the log file you see is just an old file? When I received the "Windows Resource Protection could not..." error, I was trying to run sfc from the Vista boot disk command prompt. In case it helps (or might help someone else with the same problem) - I was able to launch it by using the following switches: sfc /OFFBOOTDIR=c:\ /OFFWINDIR=c:\windows (of course, you'd have to substitute the correct drive and paths if you installed anywhere other than c:\windows). In my case, this allowed sfc to run without the "Windows Resource Protection could not..." error. Anyway - I apologize if this has already been answered or gone over; I just got lost in some of the postings. Happy Keystrokes and Footsteps! -- skitrees ------------------------------------------------------------------------ skitrees's Profile: http://forums.techarena.in/member.php?userid=49426 View this thread: http://forums.techarena.in/showthread.php?t=720382 http://forums.techarena.in |
