Help! I Can“t be longer than 30 minutes on my computer!
  1. #1
    Jeffrey v.a. Guest
    I am dutch so my englishe is not very good.
    Since i have Windows Vista my pc stops after 30 minutes. (sometimes shorter
    and sometimes any longer.)
    When i am surfing 30 minutes on internet my mouse don't move anymore and i
    can't do anything, so i must put my computer off.
    And when i'm playing a game i have this problem after 10 or 15 minutes.
    And when i'm not on my computer but he's only downloading he's do it for a
    couple of hours.
    It's very weird but it's true.
    When i had Windows XP i never had this problem.
    Please! Can someone help me?
    Cause i love Windows Vista and i never wan't XP anymore!!
    Thanks!
  2. #2
    Rick Rogers Guest
    Re: Help! I Can“t be longer than 30 minutes on my computer!
    Hi Jeffrey,
    Open the event viewer and check the system and application logs for clues.
    Does the system freeze? Or just shut down? Is there an error message?
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    "Jeffrey v.a." <Jeffrey v.a.@discussions.microsoft.com> wrote in message
    news:A53D4B95-730A-49A5-BFC9-23B9DD4CD98E@microsoft.com...
    > Hi,
    > shorter
    > couple of hours.
    > Thanks!
  3. #3
    KilrPilr Guest
    Blow the dust bunnies off of your cpu heatsink and power supply. Your
    machine is probably overheating. If its clean inside, run the task manager
    and check to see if svchost.exe is eating up your cpu cycles.
    > Hi,
    > shorter
    > couple of hours.
    > Thanks!
  4. #4
    Steve Guest
    I opened task manager on my system and found 7 instances of svchost.exe
    running at the same time. Why? and how do I stop that from happening?
    "KilrPilr" <commodore128@removehotmail.com> wrote in message
    news:j9yXh.125019$aG1.9620@pd7urf3no...
    >> Hi,
    >> shorter
    >> i
    >> a
    >> couple of hours.
    >> Thanks!
  5. #5
    Steve Guest
    Check that. I just opened it again and found 16 instances of svchost.exe
    running.
    "Steve" <jedi105@optonline.net> wrote in message
    news:OnLQin5hHHA.3472@TK2MSFTNGP04.phx.gbl...
    >> manager and check to see if svchost.exe is eating up your cpu cycles.
    >>> Hi,
    >>> shorter
    >>> i
    >>> a
    >>> couple of hours.
    >>> Thanks!
  6. #6
    Julian Guest
    news:edaDWp5hHHA.588@TK2MSFTNGP06.phx.gbl...
    > running.
    http://windowshelp.microsoft.com/Win...c91033.mspx#EV
  7. #7
    KilrPilr Guest
    Hmmm Ive never seen that many instances. Anyways what u are looking for is
    one in particular that is using up 90-100% of your cpu. Kill that process if
    possible or just go to start/control panel/system and click on the automatic
    updates tab and turn off automatic updates. There is a bug or "feature" in
    auto updates that is causing cpu's to max and computers to slow to a
    unbareable crawl.Let me know if this works for you please.
    > running.
    >>>> Hi,
    >>>> shorter
    >>>> and i
    >>>> for a
    >>>> couple of hours.
    >>>> Thanks!
  8. #8
    Rock Guest
    Why do you want to stop them? That's normal to have multiple instances
    running On this system there are 12 instances running. Each instance is a
    container for other services. From Task Manager on the process tab near the
    bottom left put a check mark in "Show processes for all users". Highlight
    an instance of svchost.exe, right click and click on "Go to services". It
    will switch tabs and highlight all the services that are running under that
    instance of svchost.exe. Check them out to see what is there. They should
    all just be windows services.
    Rock [MS-MVP User/Shell]
  9. #9
    Junior Member
    Vista Home Basic
    Local Time: 06:08 PM
    My computer has 19 instances of these what is the idea of these do I need so many??
  10. #10
    Malke Guest
    > need so many??
    Unfortunately, no one can help you because we don't know what "instance of
    these" means. See below for why and how to better get help from these
    newsgroups.
    You are not posting on a real forum as you think you are and you didn't
    quote any of the thread to which you are replying. You are using a web
    interface that leeches Usenet posts and most of the rest of us are using
    real newsreaders. We don't see what you do. If you want to participate in
    Usenet, the better way is to set up a newsreader. This is very easy to do
    and I'll give you information about that below. If you prefer to use a
    forum, then here are two excellent ones:
    http://forum.aumha.org/index.php
    http://http://computerhaven.info/
    Since you are using a web interface, you may not realize that this is really
    a newsgroup. You will get far more out of this resource if you learn to use
    a newsreader. There are many good newsreaders for Windows, but you can use
    Outlook Express (XP) or Windows Mail (Vista) since you already have it.
    Here are some links to information about newsgroups:
    About Usenet:
    http://en.wikipedia.org/wiki/Usenet
    http://www.faqs.org/faqs/ - Usenet FAQs from the Internet FAQ Archives
    http://www.usenetmonster.com/infocenter/
    http://www.elephantboycomputers.com/page2.html#Usenet - a brief explanation
    of newsgroups
    Outlook Express/Windows Mail as Newsreader:
    http://michaelstevenstech.com/outloo...snewreader.htm
    http://rickrogers.org/setupoe.htm
    http://vistasupport.mvps.org/accessi...ndows_mail.htm
    How to Post:
    http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question
    http://users.tpg.com.au/bzyhjr/liszt.htm - How Not to Get Technical Help on
    Usenet
    http://www.catb.org/~esr/faqs/smart-questions.html
    http://aumha.org/nntp.htm - list of MS newsgroups
    microsoft.public.test.here - MS group to test if your newsreader is working
    properly
    http://www3.telus.net/dandemar/munad.htm - how to munge email address
    http://en.wikipedia.org/wiki/Crossposting - crossposting
    http://www.blakjak.demon.co.uk/mul_crss.htm - multiposting
    Other Newsreaders for Windows:
    http://www.forteinc.com/main/homepage.php - Forte
    http://www.mozilla.org - Thunderbird
    Malke
    MS-MVP
    Elephant Boy Computers - Don't Panic!
    http://www.elephantboycomputers.com/#FAQ
Help! I Can“t be longer than 30 minutes on my computer! problems?
Computer has Horizontal lines after 13 minutes dayton5959 General Discussion 10 20 Feb 2009
Computer Freezes After 5 Minutes But Is OK After Reboot! Dreamliner .NET General 0 15 Nov 2008
Computer hangs at startup ... for 5 minutes!! bluevista Vista performance & maintenance 2 19 Nov 2007
Notebook computer - display turns off after 15 minutes, want it to stay on , how?? David Wess Vista General 3 03 Nov 2007
Computer freezes after log in for several minutes Jon Vista General 6 27 Sep 2007
