| | Question Regarding Flash-Drive Usage for System Memory I've seen a few vague references to improving Vista's performance by using a flash drive to augment available RAM for the operating system. Can somebody point me to a resource that provides basic details? Specifically, I would like to know if there is an upper limit to the number of GB that Vista can use for this purpose (i.e., purchasing an 8GB flash drive instead of 4GB would perhaps be a waste of money). In addition, I would like to see some opinions about whether or not a flash drive used in this way makes a noticeable difference with Vista on higher-end systems (eg: TOSHIBA laptop, INTEL duo core T2600 2.16GHZ with 2MB L2 cache, 2048MB DDR2 667MHz SDRAM, 7200RPM serial-ATA HDD, NVIDIA GEOFORCE GO7600 256MB). Cheers, ~ Mark |
| | Re: Question Regarding Flash-Drive Usage for System Memory Hi Mark, It's called ReadyBoost, and it's most effective on systems with smaller amounts of ram. Specifically, it has to be flash memory with higher read/write speeds, and it relies on the SuperFetch background process. The max it can use is 4GB. You'll find a white paper here that gets into more detail: http://www.microsoft.com/whdc/system...perfaccel.mspx -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Mark M Morse" <mmm4444bot@hotmail.com> wrote in message news:929E7E50-9715-4BA8-A92B-F5876EBB4413@microsoft.com... > I've seen a few vague references to improving Vista's performance by using > a flash drive to augment available RAM for the operating system. > > Can somebody point me to a resource that provides basic details? > > Specifically, I would like to know if there is an upper limit to the > number of GB that Vista can use for this purpose (i.e., purchasing an 8GB > flash drive instead of 4GB would perhaps be a waste of money). > > In addition, I would like to see some opinions about whether or not a > flash drive used in this way makes a noticeable difference with Vista on > higher-end systems (eg: TOSHIBA laptop, INTEL duo core T2600 2.16GHZ with > 2MB L2 cache, 2048MB DDR2 667MHz SDRAM, 7200RPM serial-ATA HDD, NVIDIA > GEOFORCE GO7600 256MB). > > Cheers, > > ~ Mark |
| | Re: Question Regarding Flash-Drive Usage for System Memory On a system with specs you describe, I don't think ReadyBoost would provide a noticeable effect. You'd do better to root out all the crapware that Toshiba may have included, and get some utilities to help tweak the performance. Microsoft has a great free download called Autoruns.zip and there's another free tool called TweakVi. I couldn't get rid of all the junk on my HP, so I had to nuke and load Vista again (and NOT from the restore disks), but now I have a fairly peppy laptop. Dana Cline - MCE MVP "Mark M Morse" <mmm4444bot@hotmail.com> wrote in message news:929E7E50-9715-4BA8-A92B-F5876EBB4413@microsoft.com... > I've seen a few vague references to improving Vista's performance by using > a flash drive to augment available RAM for the operating system. > > Can somebody point me to a resource that provides basic details? > > Specifically, I would like to know if there is an upper limit to the > number of GB that Vista can use for this purpose (i.e., purchasing an 8GB > flash drive instead of 4GB would perhaps be a waste of money). > > In addition, I would like to see some opinions about whether or not a > flash drive used in this way makes a noticeable difference with Vista on > higher-end systems (eg: TOSHIBA laptop, INTEL duo core T2600 2.16GHZ with > 2MB L2 cache, 2048MB DDR2 667MHz SDRAM, 7200RPM serial-ATA HDD, NVIDIA > GEOFORCE GO7600 256MB). > > Cheers, > > ~ Mark |
| | Re: Question Regarding Flash-Drive Usage for System Memory "Dana Cline - MVP" <dcline@scriptpro.com> wrote in message news:uhkz7kMiHHA.4976@TK2MSFTNGP03.phx.gbl... > On a system with specs you describe, I don't think ReadyBoost would > provide a noticeable effect. You'd do better to root out all the crapware > that Toshiba may have included, and get some utilities to help tweak the > performance. Microsoft has a great free download called Autoruns.zip and > there's another free tool called TweakVi. I downloaded Autoruns and gave it a spin. As a result I was able to identify loads of crapware (literally dozens of elements) left over from trials of various software tools that I have "uninstalled." On rebooting it is hard to say that there is distinct performance advantage but one thing is clear. I now have an extra 50mb+ of available RAM. 5% extra RAM whilst not huge is, IMO, still beneficial. |
| | Re: Question Regarding Flash-Drive Usage for System Memory Try the TweakVI too, it's useful! Dana Cline - MCE MVP "Julian" <Julianlzb87@gmail.com> wrote in message news:6E013F18-94F7-4FB3-B461-831E11CFDB03@microsoft.com... > "Dana Cline - MVP" <dcline@scriptpro.com> wrote in message > news:uhkz7kMiHHA.4976@TK2MSFTNGP03.phx.gbl... >> On a system with specs you describe, I don't think ReadyBoost would >> provide a noticeable effect. You'd do better to root out all the crapware >> that Toshiba may have included, and get some utilities to help tweak the >> performance. Microsoft has a great free download called Autoruns.zip and >> there's another free tool called TweakVi. > > I downloaded Autoruns and gave it a spin. > As a result I was able to identify loads of crapware > (literally dozens of elements) left over from trials of various > software tools that I have "uninstalled." > > On rebooting it is hard to say that there is distinct performance > advantage but one thing is clear. I now have an extra 50mb+ of > available RAM. > > 5% extra RAM whilst not huge is, IMO, still beneficial. > > |
| | #6 (permalink) |
| | Re: Question Regarding Flash-Drive Usage for System Memory On 27 Apr, 14:49, "Dana Cline - MVP" <dcl...@scriptpro.com> wrote: > Try theTweakVI too, it's useful! God! I hate top posting.... but, since you've been profitable up to now.... Yeah, I'll have a look but I've heard mixed, to say the least, reports about it. Cheers... :-) .. |
| | #7 (permalink) |
| | Re: Question Regarding Flash-Drive Usage for System Memory Mark - replies to your post are beginning to drift from your topic. ReadyBoost does not augment RAM - it is used as an extension to paging by "Suprfetch" - data the system determines to be in quick demand is sent to the ReadyBoost device which , if it meets specs, provides faster access than the HD. ReadyBoost can be removed at any time without loss of data since the data sent there is a copy - not original data - also the data sent to ReadyBoost is encrypted while stored. ReadyBoost works in concert with two other Ready--- items (names escape me) - initially ReadyBoost may seem to slow things down a bit - besides performing paging assistance it also monitors and tracks boot tasks and over a period of time will increase boot performance. BTW - Even though a ReadyBoost device is not installed the function is active by default (I give up on that one!). "Mark M Morse" <mmm4444bot@hotmail.com> wrote in message news:929E7E50-9715-4BA8-A92B-F5876EBB4413@microsoft.com... > I've seen a few vague references to improving Vista's performance by using > a flash drive to augment available RAM for the operating system. > > Can somebody point me to a resource that provides basic details? > > Specifically, I would like to know if there is an upper limit to the > number of GB that Vista can use for this purpose (i.e., purchasing an 8GB > flash drive instead of 4GB would perhaps be a waste of money). > > In addition, I would like to see some opinions about whether or not a > flash drive used in this way makes a noticeable difference with Vista on > higher-end systems (eg: TOSHIBA laptop, INTEL duo core T2600 2.16GHZ with > 2MB L2 cache, 2048MB DDR2 667MHz SDRAM, 7200RPM serial-ATA HDD, NVIDIA > GEOFORCE GO7600 256MB). > > Cheers, > > ~ Mark |
| Flash Drive Question | Vista hardware & devices | |||
| USB Flash Drive Memory | Vista performance & maintenance | |||
| USB Memory Stick & Flash Drive | Vista General | |||
| ReadyBoost eats up memory on my flash-drive? | Vista General | |||
| Flash drive , more memory??? | Vista General | |||
