Help With Stupid Vista Settings Configuration Thing i forgot Pleas
  1. #1
    John Guest
    I forgot how to set all the graphics and theme settings with the transparency
    and all that on Vista Premium to have the settings of Vista Basic for better
    performance. I did it before but I forgot now. Someone please tell me real
    quick.
    -John
  2. #2
    Pete Russell Guest
    Re: Help With Stupid Vista Settings Configuration Thing i forgot Pleas
    "John" <John@discussions.microsoft.com> wrote in message
    news:BA3019DD-56E1-401F-A0FA-9F5C257CB6DB@microsoft.com...
    >transparency
    > better
    > quick.
    > -John
    Right click on desktop
    Select "Personalize" > Select "Window Color and Appearance" > At bottom of
    page select the blue link that reads "Open classic appearance properties for
    more color options"
  3. #3
    Cal Bear '66 Guest
    Have you tried using Help and Support and searching for Aero?
    > quick.
    > -John
Help With Stupid Vista Settings Configuration Thing i forgot Pleas problems?
Solved really easy (stupid...) question about vista visual settings doppiedopp General Discussion 3 04 Sep 2009
Solved Vista power configuration settings are changing on their own! bondisdead General Discussion 1 10 Feb 2009
Have done a stupid thing ... AdamBC Vista file management 3 02 Jul 2007
Forgot to save my product key... Very Stupid, i know... =?Utf-8?B?SmFzcGFy?= Vista installation & setup 1 16 Jul 2006
Forgot to save my product key... Very Stupid, i know... =?Utf-8?B?SmFzcGFy?= Vista installation & setup 3 14 Jul 2006
