| | Help and Suport appears without CSS Hi! Someting strange happening in my Help and Suport Menu. It apears withouf CSS code. It seems there are in the computer some file that I lost.. Can anybody help? tks teresa |
| | Re: Help and Suport appears without CSS Hello teresa, If you can't see the Help and Support icons, here is the fix: 1. Close the Help and Support window. 2. Start the Registry Editor by clicking Start, typing "regedit" (no quotation marks), and pressing ENTER. (You need administrator privileges to do this.) 3. Navigate to HKEY_CLASSES_ROOT\.png. 4. Right-click the .png folder, point to New, and then click String value. 5. Add a new string named "Content Type" (without quotation marks). 6. Double-click the new Content Type string and set the Value data to "image/png" (without quotation marks). 7. Close the Registry Editor, and then open Help and Support. I hope this helps you with your problem. If it doesn't solve your problem, I'll need more specific information about what you are experiencing. |
| | Re: Help and Suport appears without CSS It works! Thank you Thomas! )))"Thomas Olsen [MSFT]" <tholse@online.microsoft.com> wrote in message news:1BB2E3CB-EF3A-4EA7-9589-19DDD8263061@microsoft.com... > Hello teresa, > > If you can't see the Help and Support icons, here is the fix: > > 1. Close the Help and Support window. > 2. Start the Registry Editor by clicking Start, typing "regedit" (no > quotation marks), and pressing ENTER. (You need administrator privileges > to > do this.) > 3. Navigate to HKEY_CLASSES_ROOT\.png. > 4. Right-click the .png folder, point to New, and then click String value. > 5. Add a new string named "Content Type" (without quotation marks). > 6. Double-click the new Content Type string and set the Value data to > "image/png" (without quotation marks). > 7. Close the Registry Editor, and then open Help and Support. > > I hope this helps you with your problem. > > If it doesn't solve your problem, I'll need more specific information > about what you are experiencing. > |
| | Re: Help and Suport appears without CSS Hi Thomas, I had the same problem as Theresa, but my registry already contained "image/png" for Content Type under HKEYCLASSES_ROOT/.png. I tried putting it in anyway but got the expected error message that it already existed. I have Windows Vista Ultimate (OEM version) and Help was displaying with proper CSS formatting until the formatting disappeared for no apparent reason. I would appreciate your help in getting it back. Is there something I can singularly install from the Vista DVD? Thanks, Peter -- synergy ------------------------------------------------------------------------ synergy's Profile: http://forums.techarena.in/member.php?userid=27330 View this thread: http://forums.techarena.in/showthread.php?t=738425 http://forums.techarena.in |
| | Re: Help and Suport appears without CSS Hi Peter Try similar only: 1. Close the Help and Support window. 2. Start the Registry Editor by clicking Start, typing "regedit" (no quotation marks), and pressing ENTER. (You need administrator privileges to do this.) 3. Navigate to HKEY_CLASSES_ROOT\.png. 4. Right-click the .css folder, point to New, and then click String value. 5. Add a new string named "Content Type" (without quotation marks). 6. Double-click the new Content Type string and set the Value data to "text/css" (without quotation marks). 7. Close the Registry Editor, and then open Help and Support. It worked for me. Sam -- spwestwood ------------------------------------------------------------------------ spwestwood's Profile: http://forums.techarena.in/member.php?userid=34687 View this thread: http://forums.techarena.in/showthread.php?t=738425 http://forums.techarena.in |
| An error appears | VB Script | |||
| 佄呃偙⁅呈 appears in message | Vista mail | |||
| Help and Suport missing format view | Vista General | |||
| Help and Suport lost the CSS format? | Vista General | |||
| Intel 830m Graphics Vista Suport? | Vista hardware & devices | |||
