Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Problems with zip extraction
Old 05-01-2007   #1 (permalink)
Alessandro
After changing to Visa I'm getting a real big problem with zip files: a 100Mb
file lasts more than 1 hour to be extracted. This is clearly a problem. I
tried to address the problem by using Winzip, but the problem persists.
Normal copies goes okay, this is no disk transfer rate problem... is anyone
getting some similar problem?
Thanks
Extraction Code PowerShell
Solved Extraction Fan? General Discussion
F.E.A.R and Extraction Point Vista General
iso extraction Vista installation & setup
Extraction Error Vista installation & setup
