| Guest | Remote Assist Problem I have Vista. Friend has XP. He sent a remote assist request. Worked fine until the end. Got a message that I could not connect, and that Remote Assist may have been turned off. Any Ideas what to do? -- Rich |
| Guest | Re: Remote Assist Problem Hi Rich, Is your friend behind a router? If so, his RA file may contain his local IP and not the one the router uses to connect to the outside world. For it to work, you first have to open the RA file in a text editor and change it (he should be able to supply you with the router's external IP) and he will have to enable port forwarding on the router for 3389 to internal address of his machine. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Rich Bail" <RichBail@discussions.microsoft.com> wrote in message news:B61671C4-AFB9-495F-916A-858298F4DF7F@microsoft.com... >I have Vista. Friend has XP. He sent a remote assist request. Worked fine > until the end. Got a message that I could not connect, and that Remote > Assist > may have been turned off. Any Ideas what to do? > -- > Rich |
| Guest | Re: Remote Assist Problem Thanks, but no router. Just a single PC connected to the world thru broadband (Optonline.net) connection -- Rich "Rick Rogers" wrote: > Hi Rich, > > Is your friend behind a router? If so, his RA file may contain his local IP > and not the one the router uses to connect to the outside world. For it to > work, you first have to open the RA file in a text editor and change it (he > should be able to supply you with the router's external IP) and he will have > to enable port forwarding on the router for 3389 to internal address of his > machine. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Rich Bail" <RichBail@discussions.microsoft.com> wrote in message > news:B61671C4-AFB9-495F-916A-858298F4DF7F@microsoft.com... > >I have Vista. Friend has XP. He sent a remote assist request. Worked fine > > until the end. Got a message that I could not connect, and that Remote > > Assist > > may have been turned off. Any Ideas what to do? > > -- > > Rich > > |
| Guest | Re: Remote Assist Problem Hi, I would still open and verify the IP contained in the file. Many of the home networking solutions now being provided by service providers are combination modem/router units, so there could still be some address translation. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Rich Bail" <RichBail@discussions.microsoft.com> wrote in message news:AF1C428F-CD3F-45BA-B71D-E1CAB91AA7FF@microsoft.com... > Thanks, but no router. Just a single PC connected to the world thru > broadband > (Optonline.net) connection > -- > Rich > > > "Rick Rogers" wrote: > >> Hi Rich, >> >> Is your friend behind a router? If so, his RA file may contain his local >> IP >> and not the one the router uses to connect to the outside world. For it >> to >> work, you first have to open the RA file in a text editor and change it >> (he >> should be able to supply you with the router's external IP) and he will >> have >> to enable port forwarding on the router for 3389 to internal address of >> his >> machine. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "Rich Bail" <RichBail@discussions.microsoft.com> wrote in message >> news:B61671C4-AFB9-495F-916A-858298F4DF7F@microsoft.com... >> >I have Vista. Friend has XP. He sent a remote assist request. Worked >> >fine >> > until the end. Got a message that I could not connect, and that Remote >> > Assist >> > may have been turned off. Any Ideas what to do? >> > -- >> > Rich >> >> |
| Nero driving me MAD PLEASE ASSIST | Software | |||
| Alt+tab Problems! Please assist | Vista General | |||
| Vista trouble please assist. | System Security | |||
| Making Remote Assist Work?? | Vista General | |||
| Remote Desktop problem with remote printers | Vista networking & sharing | |||
