| | #11 (permalink) |
| Newbie | Re: desktop problems? I have the same prob I get the blank srcreen with mouse pointer but no desktop.Ctrl alt delete does nothing for me.Task manager dose not start. This all started while watching a movie on Media center, movie locked up and I had to restart comp. help!! |
| | #12 (permalink) |
| Guest | Re: desktop problems? hye,rick rogers.. i have the same problem like oralay.. n i already use the way u ask to.. i click ctrl+alt+del.. then,go to file n new task.. n type "regedit" as u ask.. but the results turns to fail n its write "registry editing has been disable by your administrator".. help me please! my desktop turn blank n no task menu or even task bar.. "Rick Rogers" wrote: Quote: > Hi, > > Click start and type "regedit", then hit <enter>. Expand the branches to > reach this one: > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon > > Click on the Winlogon key (folder) and look for the shell string in the > right pane. Double click it, then delete the contents and replace it with > just "explorer.exe" (without the quotes). Click ok and close the registry > editor, then reboot to see if this helps. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message > news laray.31mow3@xxxxxx-mx.forums.net...Quote: > > > > Hello There > > > > Does anyone have a solution to this desktop problem as i am having > > exactly the same problem. When i log on into my PC running windows vista > > premium 32bit, all i get is a blank balck desktop with my document > > folder opened with no start menu or task bar. The only way i can get my > > desktop is to go into task manager and then select new task and then > > type explorer.exe. I have 3 more account set up on the PC and this is > > hapenning to all user account. I have been searching the net for the > > past month with no luck and this is the only forum that i found where > > the issue has been posted. > > Anyone who has come accross this ? I am about to rebuild the PC but if > > anyone can find a solution then that will be fab. > > Thanks > > Olaray > > > > > > -- > > olaray > |
| | #13 (permalink) |
| Guest | Re: desktop problems? Hi, Try this link: http://www.winhelponline.com/article...ows-Vista.html -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Lily" <Lily@xxxxxx> wrote in message news:AF9A144E-8708-4719-B056-ACBD8D8CBFD9@xxxxxx Quote: > hye,rick rogers.. > i have the same problem like oralay.. > n i already use the way u ask to.. > i click ctrl+alt+del.. > then,go to file n new task.. > n type "regedit" as u ask.. > but the results turns to fail n its write "registry editing has been > disable > by your administrator".. > help me please! > my desktop turn blank n no task menu or even task bar.. > > > "Rick Rogers" wrote: > Quote: >> Hi, >> >> Click start and type "regedit", then hit <enter>. Expand the branches to >> reach this one: >> >> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon >> >> Click on the Winlogon key (folder) and look for the shell string in the >> right pane. Double click it, then delete the contents and replace it with >> just "explorer.exe" (without the quotes). Click ok and close the registry >> editor, then reboot to see if this helps. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message >> news laray.31mow3@xxxxxx-mx.forums.net...Quote: >> > >> > Hello There >> > >> > Does anyone have a solution to this desktop problem as i am having >> > exactly the same problem. When i log on into my PC running windows >> > vista >> > premium 32bit, all i get is a blank balck desktop with my document >> > folder opened with no start menu or task bar. The only way i can get my >> > desktop is to go into task manager and then select new task and then >> > type explorer.exe. I have 3 more account set up on the PC and this is >> > hapenning to all user account. I have been searching the net for the >> > past month with no luck and this is the only forum that i found where >> > the issue has been posted. >> > Anyone who has come accross this ? I am about to rebuild the PC but if >> > anyone can find a solution then that will be fab. >> > Thanks >> > Olaray >> > >> > >> > -- >> > olaray >> |
| | #14 (permalink) |
| Guest | Re: desktop problems? i already try that link.. but the following instruction ask to click "start".. my desktop blank.. n dont even have task bar.. how can i click "start" button at the task bar.. my desktop blank.. dont have icon.. task bar.. or anything.. just have one file that can open internet,picture n etc. "Rick Rogers" wrote: Quote: > Hi, > > Try this link: > http://www.winhelponline.com/article...ows-Vista.html > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Lily" <Lily@xxxxxx> wrote in message > news:AF9A144E-8708-4719-B056-ACBD8D8CBFD9@xxxxxx Quote: > > hye,rick rogers.. > > i have the same problem like oralay.. > > n i already use the way u ask to.. > > i click ctrl+alt+del.. > > then,go to file n new task.. > > n type "regedit" as u ask.. > > but the results turns to fail n its write "registry editing has been > > disable > > by your administrator".. > > help me please! > > my desktop turn blank n no task menu or even task bar.. > > > > > > "Rick Rogers" wrote: > > Quote: > >> Hi, > >> > >> Click start and type "regedit", then hit <enter>. Expand the branches to > >> reach this one: > >> > >> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon > >> > >> Click on the Winlogon key (folder) and look for the shell string in the > >> right pane. Double click it, then delete the contents and replace it with > >> just "explorer.exe" (without the quotes). Click ok and close the registry > >> editor, then reboot to see if this helps. > >> > >> -- > >> Best of Luck, > >> > >> Rick Rogers, aka "Nutcase" - Microsoft MVP > >> http://mvp.support.microsoft.com/ > >> Windows help - www.rickrogers.org > >> My thoughts http://rick-mvp.blogspot.com > >> > >> "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message > >> news laray.31mow3@xxxxxx-mx.forums.net...> >> > > >> > Hello There > >> > > >> > Does anyone have a solution to this desktop problem as i am having > >> > exactly the same problem. When i log on into my PC running windows > >> > vista > >> > premium 32bit, all i get is a blank balck desktop with my document > >> > folder opened with no start menu or task bar. The only way i can get my > >> > desktop is to go into task manager and then select new task and then > >> > type explorer.exe. I have 3 more account set up on the PC and this is > >> > hapenning to all user account. I have been searching the net for the > >> > past month with no luck and this is the only forum that i found where > >> > the issue has been posted. > >> > Anyone who has come accross this ? I am about to rebuild the PC but if > >> > anyone can find a solution then that will be fab. > >> > Thanks > >> > Olaray > >> > > >> > > >> > -- > >> > olaray > >> > >> > |
| | #15 (permalink) |
| Guest | Re: desktop problems? Hi, The same way as you are trying to run regedit. Click 'new task' from Task Manager, then browse to the location where you saved the file and select it. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Lily" <Lily@xxxxxx> wrote in message news:B307A2A2-DCEE-4EE2-830B-90C5E4FF05C9@xxxxxx Quote: >i already try that link.. > but the following instruction ask to click "start".. > my desktop blank.. > n dont even have task bar.. > how can i click "start" button at the task bar.. > my desktop blank.. > dont have icon.. > task bar.. > or anything.. > just have one file that can open internet,picture n etc. > > > "Rick Rogers" wrote: > Quote: >> Hi, >> >> Try this link: >> http://www.winhelponline.com/article...ows-Vista.html >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "Lily" <Lily@xxxxxx> wrote in message >> news:AF9A144E-8708-4719-B056-ACBD8D8CBFD9@xxxxxx Quote: >> > hye,rick rogers.. >> > i have the same problem like oralay.. >> > n i already use the way u ask to.. >> > i click ctrl+alt+del.. >> > then,go to file n new task.. >> > n type "regedit" as u ask.. >> > but the results turns to fail n its write "registry editing has been >> > disable >> > by your administrator".. >> > help me please! >> > my desktop turn blank n no task menu or even task bar.. >> > >> > >> > "Rick Rogers" wrote: >> > >> >> Hi, >> >> >> >> Click start and type "regedit", then hit <enter>. Expand the branches >> >> to >> >> reach this one: >> >> >> >> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows >> >> NT\CurrentVersion\Winlogon >> >> >> >> Click on the Winlogon key (folder) and look for the shell string in >> >> the >> >> right pane. Double click it, then delete the contents and replace it >> >> with >> >> just "explorer.exe" (without the quotes). Click ok and close the >> >> registry >> >> editor, then reboot to see if this helps. >> >> >> >> -- >> >> Best of Luck, >> >> >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> >> http://mvp.support.microsoft.com/ >> >> Windows help - www.rickrogers.org >> >> My thoughts http://rick-mvp.blogspot.com >> >> >> >> "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message >> >> news laray.31mow3@xxxxxx-mx.forums.net...>> >> > >> >> > Hello There >> >> > >> >> > Does anyone have a solution to this desktop problem as i am having >> >> > exactly the same problem. When i log on into my PC running windows >> >> > vista >> >> > premium 32bit, all i get is a blank balck desktop with my document >> >> > folder opened with no start menu or task bar. The only way i can get >> >> > my >> >> > desktop is to go into task manager and then select new task and then >> >> > type explorer.exe. I have 3 more account set up on the PC and this >> >> > is >> >> > hapenning to all user account. I have been searching the net for the >> >> > past month with no luck and this is the only forum that i found >> >> > where >> >> > the issue has been posted. >> >> > Anyone who has come accross this ? I am about to rebuild the PC but >> >> > if >> >> > anyone can find a solution then that will be fab. >> >> > Thanks >> >> > Olaray >> >> > >> >> > >> >> > -- >> >> > olaray >> >> >> >> >> |
| | #16 (permalink) |
| Guest | Re: desktop problems? Thanks so much Rick... your simple steps helped me so much! : ) i was really starting to regret getting Vista for the whole 'blank desktop' deal. but your advise completely solved the problem!!! thnx again!!! -Jimmy "Rick Rogers" wrote: Quote: > Hi, > > Click start and type "regedit", then hit <enter>. Expand the branches to > reach this one: > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon > > Click on the Winlogon key (folder) and look for the shell string in the > right pane. Double click it, then delete the contents and replace it with > just "explorer.exe" (without the quotes). Click ok and close the registry > editor, then reboot to see if this helps. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message > news laray.31mow3@xxxxxx-mx.forums.net...Quote: > > > > Hello There > > > > Does anyone have a solution to this desktop problem as i am having > > exactly the same problem. When i log on into my PC running windows vista > > premium 32bit, all i get is a blank balck desktop with my document > > folder opened with no start menu or task bar. The only way i can get my > > desktop is to go into task manager and then select new task and then > > type explorer.exe. I have 3 more account set up on the PC and this is > > hapenning to all user account. I have been searching the net for the > > past month with no luck and this is the only forum that i found where > > the issue has been posted. > > Anyone who has come accross this ? I am about to rebuild the PC but if > > anyone can find a solution then that will be fab. > > Thanks > > Olaray > > > > > > -- > > olaray > |
| | #17 (permalink) |
| Guest | Re: desktop problems? Rick, I just felt I should say thankyou.. what with the amount of people you've probably helped here and none saying thanks! Had the blank desktop, but works perfectly after following your instructions. Cheers from England! -Tom |
| | #18 (permalink) |
| Guest | Re: desktop problems? What is the shell String. Did everything up to that but you then lost me at Click on the Winlogon key (folder) and look for the shell string in the right pane. Double click it, then delete the contents and replace it with just "explorer.exe" (without the quotes). Click ok and close the registry editor, then reboot to see if this helps. "ash_chaingang" wrote: Quote: > Thanks so much Rick... > your simple steps helped me so much! : ) > i was really starting to regret getting Vista for the whole 'blank desktop' > deal. > but your advise completely solved the problem!!! > thnx again!!! > -Jimmy > > "Rick Rogers" wrote: > Quote: > > Hi, > > > > Click start and type "regedit", then hit <enter>. Expand the branches to > > reach this one: > > > > HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon > > > > Click on the Winlogon key (folder) and look for the shell string in the > > right pane. Double click it, then delete the contents and replace it with > > just "explorer.exe" (without the quotes). Click ok and close the registry > > editor, then reboot to see if this helps. > > > > -- > > Best of Luck, > > > > Rick Rogers, aka "Nutcase" - Microsoft MVP > > http://mvp.support.microsoft.com/ > > Windows help - www.rickrogers.org > > My thoughts http://rick-mvp.blogspot.com > > > > "olaray" <olaray.31mow3@xxxxxx-mx.forums.net> wrote in message > > news laray.31mow3@xxxxxx-mx.forums.net...Quote: > > > > > > Hello There > > > > > > Does anyone have a solution to this desktop problem as i am having > > > exactly the same problem. When i log on into my PC running windows vista > > > premium 32bit, all i get is a blank balck desktop with my document > > > folder opened with no start menu or task bar. The only way i can get my > > > desktop is to go into task manager and then select new task and then > > > type explorer.exe. I have 3 more account set up on the PC and this is > > > hapenning to all user account. I have been searching the net for the > > > past month with no luck and this is the only forum that i found where > > > the issue has been posted. > > > Anyone who has come accross this ? I am about to rebuild the PC but if > > > anyone can find a solution then that will be fab. > > > Thanks > > > Olaray > > > > > > > > > -- > > > olaray > > |
| | #19 (permalink) |
| Newbie | Re: desktop problems? so after i start new task manager and bring up explorer and i bring up the registry and get HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon i dont even have a winlogon folder (or i cant find it) all i have is HKEY_LOCAL_MACHINE and then when i expand it i have these sub folders BCD0000000,COMPONENTS,HARDWARE,SAM,SECURITY,SOFTWARE,SYSTEM i need help Rick |
| | #20 (permalink) |
| Guest | Re: desktop problems? Go here: http://www.paulsxp.com/forum/viewtopic.php?f=16&t=108 Download ListWinlogon and run the script, it will list what is in the Winlogon Key. -- ------------------------------------------------------------------------------------- www.paulsxp.com www.paulsxp.com/forum http://www.supportspace.com/home/aff...s.s2?aiu=paulm ------------------------------------------------------------------------------------ "johnny handrail" <guest@xxxxxx-email.com> wrote in message news:0d143673f1529914741e69b2744c148e@xxxxxx-gateway.com... Quote: > > so after i start new task manager and bring up explorer and i bring up > the registry > and get HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows > NT\CurrentVersion\Winlogon > > > i dont even have a winlogon folder (or i cant find it) all i have is > HKEY_LOCAL_MACHINE and then when i expand it i have these sub folders > BCD0000000,COMPONENTS,HARDWARE,SAM,SECURITY,SOFTWARE,SYSTEM > > i need help Rick > > > -- > johnny handrail |
| Desktop Problems | .NET General | |||
| Desktop problems | Vista performance & maintenance | |||
| Desktop Problems | General Discussion | |||
| desktop problems | Vista installation & setup | |||
| Desktop Problems | Vista General | |||
