Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - desktop problem
Old 05-20-2007   #1 (permalink)
stevie mcg
desktop problem
for some reason since I installed Vista on my laptop, everytime I have
successfully logged into the system I have to use the Task manager and use
the New task function to start "explorer.exe" otherwise the screen in blank
with nothing on it. It seems that windows isn't automatically starting the
explorer task as it should. Are there any steps I can follow to rectify this
situation?
Old 05-20-2007   #2 (permalink)
Reeko
RE: desktop problem
what operting system did you have before? You mite have not instal Vista
fully i could have miss a program maybe you have to re-instal it
> situation?
Old 05-20-2007   #3 (permalink)
Ronnie Vernon MVP
Re: desktop problem
"stevie mcg" <steviemcg@discussions.microsoft.com> wrote in message
news:94EBB4D0-5460-46EB-8E07-CD3571FFBBFC@microsoft.com...
> blank
> this
> situation?
Stevie
Open Notepad and copy / paste the 3 lines of text between the 2 dashed
lines. (Don't copy the dashed lines and make sure it is copied exactly as
shown, with no line wrap)
Select File / Save and save the file to the Desktop. Name the file
Shell.reg
Close Notepad, go to the Desktop and double click the file. OK all of the
prompts to merge the file into the registry. Reboot the computer.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"Shell"="explorer.exe"
Ronnie Vernon
Microsoft MVP
Windows Shell/User
Desktop Problem :/ General Discussion
Desktop Problem General Discussion
Desktop to desktop network problem Network & Sharing
Desktop Problem Help!!! Vista General
desktop.ini problem Vista General
