Screen Saver Will Not Work
  1. #1
    Sidney Friedman Guest
    I have a new Toshiba Laptop with Vista Ultimate OS. My screen savers will
    not work. I can access them in the Control Panel and even "preview" them.
    However, after some time the screen saver will not kick in.
    Any suggestions will be appreciated.
  2. #2
    mikeyhsd Guest
    Re: Screen Saver Will Not Work
    sometimes bluetooth and usb mouse are knows to prevent activation of screensaver.
    also you should check the power mode you are using and its settings to see if it might be interfering.
    mikeyhsd@comcast.net
    "Sidney Friedman" <counsel2@sbcglobal.net> wrote in message news:isJ4i.5936$4Y.1181@newssvr19.news.prodigy.net...
  3. #3
    Thanks for your reply mikeyhsd,
    I am using a usb wireless mouse. My power mode is set on "Balanced". what
    do you suggest?
    "mikeyhsd" <mikeyhsd@comcast.net> wrote in message
    news:ejEdbQMnHHA.4424@TK2MSFTNGP03.phx.gbl...
    screensaver.
  4. #4
    mikeyhsd Guest
    check for newer drivers for the mouse.
    or as silly ass it sounds, turn the mouse upside down when not using it.
    "Sidney Friedman" <counsel2@sbcglobal.net> wrote in message news:l4L4i.1916$C96.427@newssvr23.news.prodigy.net...
    do you suggest?
    screensaver.
Screen Saver Will Not Work counsel Vista installation & setup 10 19 Nov 2008
Screen Saver won't work Spider Vista General 4 14 Nov 2008
Screen saver does not work Unhappy with Vista Vista performance & maintenance 10 02 Oct 2008
Screen Saver - DOES NOT WORK Frozenscrolls Vista performance & maintenance 2 27 Dec 2007
Screen Saver does not work Kevin S. Vista performance & maintenance 1 02 Jul 2007
