| | Hibernation and shutdown problems... I use Windows Vista ultimate on my DELL. When ever I click hibernate, restart or shut down, my computer shows a black screen with the disk usage light blinking randomly. I have all recent updates. Why? I want to be able to turn off my pc normally! |
| | Re: Hibernation and shutdown problems... Hello, My name is Richard; I work for Dell's Online Community Outreach group here in Round Rock, Texas. Please indicate the Dell model that you are experiencing the hibernation issue and any other information that may assist with locating a solution to this problem. Thanks, Richard B Dell Online Community Outreach -- DellCA ------------------------------------------------------------------------ DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 View this thread: http://forums.techarena.in/showthread.php?t=759140 http://forums.techarena.in |
| | Re: Hibernation and shutdown problems... DELL Inspiron 6000 "DellCA" wrote: > > Hello, > > My name is Richard; I work for Dell's Online Community Outreach group > here in Round Rock, Texas. Please indicate the Dell model that you are > experiencing the hibernation issue and any other information that may > assist with locating a solution to this problem. > > Thanks, > > Richard B > Dell Online Community Outreach > > > -- > DellCA > ------------------------------------------------------------------------ > DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 > View this thread: http://forums.techarena.in/showthread.php?t=759140 > > http://forums.techarena.in > > |
| | Re: Hibernation and shutdown problems... jonah_thebest;2936080 Wrote: > DELL Inspiron 6000 > > "DellCA" wrote: > > > > > Hello, > > > > My name is Richard; I work for Dell's Online Community Outreach > group > > here in Round Rock, Texas. Please indicate the Dell model that you > are > > experiencing the hibernation issue and any other information that > may > > assist with locating a solution to this problem. > > > > Thanks, > > > > Richard B > > Dell Online Community Outreach > > > > > > -- > > DellCA > > > ------------------------------------------------------------------------ > > DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 > > View this thread: http://forums.techarena.in/showthread.php?t=759140 > > > > http://forums.techarena.in > > > > Hello, The Inspiron 6000 was designed for Windows XP, way before Vista came out, so most likely you never had this issue when you first got the system with XP installed. However, your computer should work with Vista, but you must update a few things. First make sure that you have the latest bios update, http://tinyurl.com/249kwf. When the update is complete, reset the bios factory defaults. To reset the factory defaults, press ALT+F while inside the bios. Reinstall your copy of Vista and apply the drivers from our download site, http://support.dell.com/support/down...=19&l=en&s=dhs. Make sure to select Vista for driver language. Let us know how this works out. Good luck. Regards, Richard B Dell Online Community Outreach -- DellCA ------------------------------------------------------------------------ DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 View this thread: http://forums.techarena.in/showthread.php?t=759140 http://forums.techarena.in |
| | Re: Hibernation and shutdown problems... Richard B Dell Online Community Outreach Dear Richard, I have just bought a state-of-the-art Dell Latitude D830 machine (Dual Proc, 2.4 GHz, 2GB Ram). It came with MS Vista Businiss as a pre-installed OS. I am facing a problem when ever I come back from Hibernate mode in which the system fails to continue and it give a message that there is a "Bad_Pool" in a DOS Screen. I am very familier with Hibernation and used to use since it was introduce by MS. I hope the problem is not with a bad design the newely desinged Latitude. Many thanks, bu_plus -- bu_plus ------------------------------------------------------------------------ bu_plus's Profile: http://forums.techarena.in/member.php?userid=28890 View this thread: http://forums.techarena.in/showthread.php?t=759140 http://forums.techarena.in |
| | #6 (permalink) |
| | Re: Hibernation and shutdown problems... Hi, BAD_POOL_CALLER is a driver error message. One or more of the drivers in the system is either corrupt, in conflict with another driver, or not compatible with the hibernate function. It could be a system supplied driver with the Dell version of Vista, or one added by software installed on the system. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "bu_plus" <bu_plus.2us2nf@DoNotSpam.com> wrote in message news:bu_plus.2us2nf@DoNotSpam.com... > > Richard B > Dell Online Community Outreach > > Dear Richard, > > I have just bought a state-of-the-art Dell Latitude D830 machine (Dual > Proc, 2.4 GHz, 2GB Ram). It came with MS Vista Businiss as a > pre-installed OS. > > I am facing a problem when ever I come back from Hibernate mode in > which the system fails to continue and it give a message that there is > a "Bad_Pool" in a DOS Screen. > > I am very familier with Hibernation and used to use since it was > introduce by MS. > > I hope the problem is not with a bad design the newely desinged > Latitude. > > Many thanks, > > bu_plus > > > -- > bu_plus > ------------------------------------------------------------------------ > bu_plus's Profile: http://forums.techarena.in/member.php?userid=28890 > View this thread: http://forums.techarena.in/showthread.php?t=759140 > > http://forums.techarena.in > |
| | #7 (permalink) |
| | Re: Hibernation and shutdown problems... Dear Rick, Thank you for your kind reply. If the source of the problem is a driver, as you have suggested. How can I know which one. I've already went to the Device Manager and found no hardware or software conflict messages there. Any suggestions? Best regarads, bu_plus -- bu_plus ------------------------------------------------------------------------ bu_plus's Profile: http://forums.techarena.in/member.php?userid=28890 View this thread: http://forums.techarena.in/showthread.php?t=759140 http://forums.techarena.in |
| | #8 (permalink) |
| | Re: Hibernation and shutdown problems... Hi, Start by checking for unsigned drivers. Run verifier.exe. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "bu_plus" <bu_plus.2usm3k@DoNotSpam.com> wrote in message news:bu_plus.2usm3k@DoNotSpam.com... > > Dear Rick, > > Thank you for your kind reply. > If the source of the problem is a driver, as you have suggested. How > can I know which one. I've already went to the Device Manager and > found no hardware or software conflict messages there. > > Any suggestions? > > Best regarads, > > bu_plus > > > -- > bu_plus > ------------------------------------------------------------------------ > bu_plus's Profile: http://forums.techarena.in/member.php?userid=28890 > View this thread: http://forums.techarena.in/showthread.php?t=759140 > > http://forums.techarena.in > |
| | #9 (permalink) |
| | Re: Hibernation and shutdown problems... Hi, I run the verifier, no conflict messages where found! Is there any other steps that I can do to find the source of the problem. Best regards, bu_plus -- bu_plus ------------------------------------------------------------------------ bu_plus's Profile: http://forums.techarena.in/member.php?userid=28890 View this thread: http://forums.techarena.in/showthread.php?t=759140 http://forums.techarena.in |
| Vista Hibernation Problems? | General Discussion | |||
| SP1 Shutdown and hibernation possible issue on old 2004 HP compute | Vista hardware & devices | |||
| Major problems after hibernation | Vista General | |||
| Hibernation problems | Vista General | |||
| Serious sleep and hibernation problems | Vista General | |||
