Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - System Restore problem
Old 06-03-2007   #1 (permalink)
Ricky Cheng
Guest
Can't create system restore point, the error code it told me is 0x8004230c
The disk not support shadow copy..
I am using Vista Home primium and NTFS Harddisk
Volume Shadow Copy service is turned on..
20GB space..
Why still can't do that?
Please offer help
Old 08-06-2007   #2 (permalink)
Newbie
Pacard Bell
Re: System Restore problem
Quote  Quote: Originally Posted by Ricky Cheng View Post
20GB space..
Please offer help
I have the same problem. Please, help me.
Old 08-06-2007   #3 (permalink)
Malke
Guest
> 20GB space..
> Please offer help
Missing Restore Points/Shadow Copies in Windows Vista -
http://bertk.mvps.org/html/missingrpv.html
Also see:
System Restore - Error Messages in Vista
http://bertk.mvps.org/html/eerrormsgsv.html
And if you have a Symantec product installed:
Problems caused by Symantec - http://bertk.mvps.org/html/symantecdoc1.html
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 08-07-2007   #4 (permalink)
Bert Kinney
Guest
Hi Ricky,
Are there any external drives connected to the computer?
Regards,
Bert Kinney MS-MVP Shell/User
Member: http://dts-l.org
> 20GB space..
> Please offer help
Old 08-07-2007   #5 (permalink)
Christine [MSFT]
Guest
Hi Damian, does this error happen when you try to manually create a restore
point, during app/driver install or other situations?
Christine
"DamianKordian" <DamianKordian.2uwiu6@no-mx.forums.net> wrote in message
newsamianKordian.2uwiu6@no-mx.forums.net...
>> 0x8004230c
>> 20GB space..
>> Please offer help
> DamianKordian
system restore Problem General Discussion
System Restore Problem General Discussion
System Restore problem Vista General
problem with system restore Vista General
System Restore Problem? Vista General
