| | Vista - System Volume Information |
| 06-14-2007 | #1 (permalink) |
| | System Volume Information I have noticed that my System Volume Information folder is very big. I cleared the restores and it went down to 600MB because it has to leave the lastest. However, after 4 days, it has already risen to 5GB in size. My hard disk is 160GB capcacity. How large should the folder be and will it rise to a certain point and then stop? What proportion of the drive does the folder take up. |
| My System Specs |
| 06-14-2007 | #2 (permalink) |
| | Re: System Volume Information "Gideon_CC" wrote >I have noticed that my System Volume Information folder is very big. > I cleared the restores and it went down to 600MB because it has to leave > the > lastest. > However, after 4 days, it has already risen to 5GB in size. > > My hard disk is 160GB capcacity. > How large should the folder be and will it rise to a certain point and > then > stop? > What proportion of the drive does the folder take up. I believe the default is 15% of the drive. You can see what is used and the maximum allocated by running the vssadmin command tool from an elevated command prompt. Do vssadmin /? to see the options. With this you can also limit the size allocated for Shadow copies using vssadmin resize shadowstorage For example to limit the size to 7GB on the D: volume the command would be: vssadmin resize shadowstorage /on=D: /for=D: /maxsize=7GB -- Rock [MS-MVP User/Shell] |
| My System Specs |
| 06-14-2007 | #3 (permalink) |
| | Re: System Volume Information Hi, I believe the default to be roughly 12% of the drive. In your case this would mean 19.6GB. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message news:8809B0B7-3247-464A-95AD-980BA4281F83@microsoft.com... >I have noticed that my System Volume Information folder is very big. > I cleared the restores and it went down to 600MB because it has to leave > the > lastest. > However, after 4 days, it has already risen to 5GB in size. > > My hard disk is 160GB capcacity. > How large should the folder be and will it rise to a certain point and > then > stop? > What proportion of the drive does the folder take up. |
| My System Specs |
| 06-15-2007 | #4 (permalink) |
| | Re: System Volume Information I did the command: List ShadowStorage and the follow came up: hadow Copy Storage association For volume: (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e6963}\Shadow Copy Storage volume: (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e6963}\ Used Shadow Copy Storage space: 637.688 MB Allocated Shadow Copy Storage space: 857.906 MB Maximum Shadow Copy Storage space: 10.932 GB Does this mean the maximum folder size for System Volume Information is 10GB or for a single backup or something. How can I see what it is currently set to and what the current maximum amount is? "Rick Rogers" wrote: > Hi, > > I believe the default to be roughly 12% of the drive. In your case this > would mean 19.6GB. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message > news:8809B0B7-3247-464A-95AD-980BA4281F83@microsoft.com... > >I have noticed that my System Volume Information folder is very big. > > I cleared the restores and it went down to 600MB because it has to leave > > the > > lastest. > > However, after 4 days, it has already risen to 5GB in size. > > > > My hard disk is 160GB capcacity. > > How large should the folder be and will it rise to a certain point and > > then > > stop? > > What proportion of the drive does the folder take up. > > |
| My System Specs |
| 06-15-2007 | #5 (permalink) |
| | Re: System Volume Information Hi, The last figure is the maximum size allocated for all of the backups, and actually it should be higher. I stated 12%, but Rock is correct that it should be around 15% (I was thinking about XP for some reason). -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message news:77858877-F461-452B-A55D-A50158496B81@microsoft.com... >I did the command: > > List ShadowStorage > > and the follow came up: > > hadow Copy Storage association > For volume: (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e6963}\> Shadow Copy Storage volume: > (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e69> 63}\ > Used Shadow Copy Storage space: 637.688 MB > Allocated Shadow Copy Storage space: 857.906 MB > Maximum Shadow Copy Storage space: 10.932 GB > > Does this mean the maximum folder size for System Volume Information is > 10GB > or for a single backup or something. How can I see what it is currently > set > to and what the current maximum amount is? > > "Rick Rogers" wrote: > >> Hi, >> >> I believe the default to be roughly 12% of the drive. In your case this >> would mean 19.6GB. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message >> news:8809B0B7-3247-464A-95AD-980BA4281F83@microsoft.com... >> >I have noticed that my System Volume Information folder is very big. >> > I cleared the restores and it went down to 600MB because it has to >> > leave >> > the >> > lastest. >> > However, after 4 days, it has already risen to 5GB in size. >> > >> > My hard disk is 160GB capcacity. >> > How large should the folder be and will it rise to a certain point and >> > then >> > stop? >> > What proportion of the drive does the folder take up. >> >> |
| My System Specs |
| 06-15-2007 | #6 (permalink) |
| | Re: System Volume Information Why do you think it is smaller than you say it should be? Do you think it will change? I did a cleaned up system restore yesterday buts its up to 1GB in size now. "Rick Rogers" wrote: > Hi, > > The last figure is the maximum size allocated for all of the backups, and > actually it should be higher. I stated 12%, but Rock is correct that it > should be around 15% (I was thinking about XP for some reason). > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message > news:77858877-F461-452B-A55D-A50158496B81@microsoft.com... > >I did the command: > > > > List ShadowStorage > > > > and the follow came up: > > > > hadow Copy Storage association > > For volume: (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e6963}\> > Shadow Copy Storage volume: > > (C \\?\Volume{96d66944-05f6-11dc-8728-806e6f6e69> > 63}\ > > Used Shadow Copy Storage space: 637.688 MB > > Allocated Shadow Copy Storage space: 857.906 MB > > Maximum Shadow Copy Storage space: 10.932 GB > > > > Does this mean the maximum folder size for System Volume Information is > > 10GB > > or for a single backup or something. How can I see what it is currently > > set > > to and what the current maximum amount is? > > > > "Rick Rogers" wrote: > > > >> Hi, > >> > >> I believe the default to be roughly 12% of the drive. In your case this > >> would mean 19.6GB. > >> > >> -- > >> Best of Luck, > >> > >> Rick Rogers, aka "Nutcase" - Microsoft MVP > >> http://mvp.support.microsoft.com/ > >> Windows help - www.rickrogers.org > >> My thoughts http://rick-mvp.blogspot.com > >> > >> "Gideon_CC" <GideonCC@discussions.microsoft.com> wrote in message > >> news:8809B0B7-3247-464A-95AD-980BA4281F83@microsoft.com... > >> >I have noticed that my System Volume Information folder is very big. > >> > I cleared the restores and it went down to 600MB because it has to > >> > leave > >> > the > >> > lastest. > >> > However, after 4 days, it has already risen to 5GB in size. > >> > > >> > My hard disk is 160GB capcacity. > >> > How large should the folder be and will it rise to a certain point and > >> > then > >> > stop? > >> > What proportion of the drive does the folder take up. > >> > >> > > |
| My System Specs |
| Similar Threads for: System Volume Information | ||||
| 43 GB System File in System Volume Information on 160 GB partition | Vista General | |||
| Get rid of System Volume Information | Vista file management | |||
| System Volume Information | Vista performance & maintenance | |||
| system volume information? What is it? | Vista General | |||
| Need to fix System Volume Information | Vista security | |||
