| | Battery meter not showing time remaining In my Laptop with Vista Home Prem installed the battery meter in the system tray only shows the percentage of battery life remaining. It does not show the estimated time remaining. My two other Vista Premium laptops did display both the % and time estimate. Is there a setting to turn it on? Thanks. |
| | Re: Battery meter not showing time remaining Hi, My HP laptop only shows the charge percentage as well and I know of no way to alter this. I suspect that what is displayed is determined by the power management drivers, so there are no settings that can be adjusted. Time remaining under battery power is very dependent on the level of usage as well, so any estimations of time remaining (which is all those really are, estimates) based on percentage of discharge could be off considerably if usage is heavy or light. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "diesel" <diesel@discussions.microsoft.com> wrote in message news:E0F4452D-FBB7-400C-8F7C-F5E3DA940D5B@microsoft.com... > In my Laptop with Vista Home Prem installed the battery meter in the > system > tray only shows the percentage of battery life remaining. It does not > show > the estimated time remaining. My two other Vista Premium laptops did > display > both the % and time estimate. > > Is there a setting to turn it on? > > Thanks. |
| | Re: Battery meter not showing time remaining Thanks for the reply. "Rick Rogers" wrote: > Hi, > > My HP laptop only shows the charge percentage as well and I know of no way > to alter this. I suspect that what is displayed is determined by the power > management drivers, so there are no settings that can be adjusted. Time > remaining under battery power is very dependent on the level of usage as > well, so any estimations of time remaining (which is all those really are, > estimates) based on percentage of discharge could be off considerably if > usage is heavy or light. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "diesel" <diesel@discussions.microsoft.com> wrote in message > news:E0F4452D-FBB7-400C-8F7C-F5E3DA940D5B@microsoft.com... > > In my Laptop with Vista Home Prem installed the battery meter in the > > system > > tray only shows the percentage of battery life remaining. It does not > > show > > the estimated time remaining. My two other Vista Premium laptops did > > display > > both the % and time estimate. > > > > Is there a setting to turn it on? > > > > Thanks. > > |
| | Re: Battery meter not showing time remaining So what? I used to have time remaining as well. The question isn't whether or not it's accurate, it's why the remaining time disappeared in the first place. I've seen two other laptops that show it. What's the deal? "diesel" <diesel@discussions.microsoft.com> wrote in message news:E124413A-CC4C-4C2F-A09F-1D5126BDCABC@microsoft.com... > Thanks for the reply. > > > "Rick Rogers" wrote: > >> Hi, >> >> My HP laptop only shows the charge percentage as well and I know of no >> way >> to alter this. I suspect that what is displayed is determined by the >> power >> management drivers, so there are no settings that can be adjusted. Time >> remaining under battery power is very dependent on the level of usage as >> well, so any estimations of time remaining (which is all those really >> are, >> estimates) based on percentage of discharge could be off considerably if >> usage is heavy or light. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "diesel" <diesel@discussions.microsoft.com> wrote in message >> news:E0F4452D-FBB7-400C-8F7C-F5E3DA940D5B@microsoft.com... >> > In my Laptop with Vista Home Prem installed the battery meter in the >> > system >> > tray only shows the percentage of battery life remaining. It does not >> > show >> > the estimated time remaining. My two other Vista Premium laptops did >> > display >> > both the % and time estimate. >> > >> > Is there a setting to turn it on? >> > >> > Thanks. >> >> |
| | RE: Battery meter not showing time remaining I also have and HP. I've thought of deleting hp drivers, but I'm not sure I should do so. Why does Microsoft have to reinvent the wheel? Why aren't we getting our darn minutes displayed. Can anyone please help? "diesel" wrote: > In my Laptop with Vista Home Prem installed the battery meter in the system > tray only shows the percentage of battery life remaining. It does not show > the estimated time remaining. My two other Vista Premium laptops did display > both the % and time estimate. > > Is there a setting to turn it on? > > Thanks. |
| battery doesn't show time remaining | Vista General | |||
| Remaining Battery Time | Vista hardware & devices | |||
| Remaining Battery Time | Vista General | |||
| Battery Meter does not show time remaining. | Vista General | |||
| Toshiba Satellite Pro - Battery Meter at 100% all the time | Vista hardware & devices | |||
