Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Scanner will not work
Old 06-28-2007   #1 (permalink)
mikerapolas
I installed Vista on 5/2. i have an Epson CX6400 all in one.
Up until 10 days ago my scanner was working properly. Now it will not scan.
I am told that I do not have "Microsoft WPD filesystems volume driver".
I tried to update this and I am told that my driver is up to date. ??? No
scanner.
I have reinstalled the software for the printer. No scanner. It looks to me
to be a Microsoft Vista problem. But I don't know.
Can anyone help me or try to poine me in the right direction?
Thank you so much.
Sincerely, Mike
Thank you so much, Mike
Old 06-28-2007   #2 (permalink)
R. C. White
Re: Scanner will not work
Hi, Mike.
Are you sure you have the right driver for that device? Microsoft WPD
stands for Windows Portable Device. The CX6400 is not a portable device, is
it?
A quick Google search on "Epson CX6400" brought me here:
http://www.epson.com/cgi-bin/Store/s...Type=Downloads
The first item on that page is:
TWAIN Driver and EPSON Scan Utility v3.04A
Windows Vista 64-bit Edition, Windows Vista 32-bit Edition
epson12258.exe - 21.1MB - posted on 04/25/07
....and there is a Download button.
Is this the right one for your scanner?
RC
R. C. White, CPA
San Marcos, TX
rc@grandecom.net
Microsoft Windows MVP
(Running Windows Live Mail beta in Vista Ultimate x64)
"mikerapolas" <mrapolas@tampabay.rr.com(donotspam)> wrote in message
news:1E7AD2EC-331F-47B1-9695-7C1ADE6A582E@microsoft.com...
> scan.
> scanner.
> me
> Thank you so much.
> Sincerely, Mike
Old 06-29-2007   #3 (permalink)
Spirit
Try turning UAC off and see if the scanner works now.... reboot after turn
UAC off.
> scan.
> scanner.
> me
> Thank you so much.
> Sincerely, Mike
Old 06-29-2007   #4 (permalink)
mikerapolas
Thanks R.C. & Spirit,
I have tried your suggestions but neither was successful.
Every time I try to install the WPD driver it is successful but upon
selection of the scanner I am told that I need to install the WPD driver.
Does it sound like I am caught in a loop? And if so how do you think I can
get out of it?
> UAC off.
> > scan.
> > scanner.
> > me
> > Thank you so much.
> > Sincerely, Mike
Old 06-29-2007   #5 (permalink)
R. C. White
Hi, Mike.
Instead of saying that you "tried your suggestions", please tell us, step by
step, exactly what you did and what results you saw, including - verbatim -
any error messages. That way, we will know if our suggestions were clear
enough.
Did you go to the Epson link I gave, download the Vista drivers and install
them? What driver version shows in Device Manager for that scanner?
Maybe you don't need new drivers from Epson at all. Vista comes with
drivers for MANY devices already built-in. What do you see if you click
Control Panel | Scanners and Cameras? (You'll need to have your Epson
connected and turned on - and you'll have to be running as Administrator.)
If your Epson appears, click Properties, then Test Scanner. What were your
results?
When I bought my HP OfficeJet G55 in 2000, HP promised Win2K software "Real
Soon Now". It took them TWO YEARS to deliver! By then I had retired Win2K
and was running WinXP. The good news is that I didn't really need all the
extra fluff that HP bundled in their software. The drivers built into WinXP
provided all the functionality - including scanning - that I needed. HP's
software bundle (when it finally arrived) also included applications to
print brochures and other fancy projects. Nice, but certainly not
necessary. Most could be done just as well with Word or Publisher or some
other program.
What did Epson say when you asked them? Remember that Microsoft writes
Vista, but it is the hardware manufacturer's responsibility to provide the
drivers that allow their products to work with Vista. And that URL I gave
you for Epson DOES include a Support link.
RC
R. C. White, CPA
San Marcos, TX
rc@grandecom.net
news:78874B59-3DD0-44F2-B537-BBD69873472E@microsoft.com...
> get out of it?
>> turn
>> UAC off.
>> > scan.
>> > No
>> > scanner.
>> > to
>> > me
>> > Thank you so much.
>> > Sincerely, Mike
Old 06-29-2007   #6 (permalink)
Spirit
When you installed the driver did you right click on the file name
and select Run as Admin? Do same with the program you use
to run the scanner.
> get out of it?
>> turn
>> UAC off.
>> > scan.
>> > No
>> > scanner.
>> > to
>> > me
>> > Thank you so much.
>> > Sincerely, Mike
Old 06-30-2007   #7 (permalink)
mikerapolas
I have reinstalled the software.
I have installed the updates.
I have tried to run as administrator.
All with the same result-"epson scan cannoy be started"
I have tried to go to Epson scanner setup-results are error that stated
"scanner not ready. Interface not connected"
I have checked the USB cable and everything is good. I have it plugged into
the first connection point.
I am really stuck here, I need this scanner.
Thanks, Mike
> to run the scanner.
> > get out of it?
> >> turn
> >> UAC off.
> >> > scan.
> >> > No
> >> > scanner.
> >> > to
> >> > me
> >> > Thank you so much.
> >> > Sincerely, Mike
Old 06-30-2007   #8 (permalink)
R. C. White
Hi, Mike.
Three actions that were not in your list of things you've done:
1. Have you visited Windows Update?
2. Have you tried Update Drivers - and let it search everywhere, including
the Internet?
3. Have you tried completely removing drivers and other software for this
printer/scanner, then shutting down the computer, unplugging the
printer/scanner and rebooting a couple of times - then shutting down and
plugging in the printer/scanner and rebooting one more time? This often
lets Vista detect the hardware and install the proper drivers from the Vista
DVD.
You've probably done all of those - at least once - but I can't find any
mention of those actions in your 3 posts.
By the way, at the risk of simply adding to your frustration...
What software? Name, source, version? The URL I gave you in my first post
offers 3.04A. Is that the version that you installed?
As I said, the DRIVERS provide basic functionality; do you have that with
your scanner? The SOFTWARE typically bundled with a printer/scanner usually
adds bell and whistles. And drivers are the responsibility of Epson, in
this case, not Microsoft, but the Vista DVD does include many drivers that
MS received from hardware vendors.
Which updates? From Epson? From Windows Update? Which versions?
All those version numbers and stuff may not mean much to you - or to me -
but they might be critical to readers who are familiar with the CX4600, and
who just might know which versions DO work with Vista. It couldn't hurt to
try. ;^}
RC
R. C. White, CPA
San Marcos, TX
rc@grandecom.net
news:4DDED7CA-156C-4F1F-88EE-6A619F270577@microsoft.com...
> into
> Thanks, Mike
>> to run the scanner.
>> > driver.
>> > can
>> > get out of it?
>> >> turn
>> >> UAC off.
>> >> > not
>> >> > scan.
>> >> > driver".
>> >> > No
>> >> > scanner.
>> >> > looks
>> >> > to
>> >> > me
>> >> > Thank you so much.
>> >> > Sincerely, Mike
Old 07-02-2007   #9 (permalink)
Spirit
If its a USB scanner try using a Powered USB Port/Hub..... could be its
drawing
more USB power than your computer can deliver.
> into
> Thanks, Mike
>> to run the scanner.
>> > driver.
>> > can
>> > get out of it?
>> >> turn
>> >> UAC off.
>> >> > not
>> >> > scan.
>> >> > driver".
>> >> > No
>> >> > scanner.
>> >> > looks
>> >> > to
>> >> > me
>> >> > Thank you so much.
>> >> > Sincerely, Mike
Old 07-09-2007   #10 (permalink)
Mo4
I have written my 8th letter to Epson on my Epson all in one CX7800 Printer/Scanner. Mine was working and just quit. I'm not sure if it was from an update or what. I had to originally installed new drivers and it was working when I first got my new computer w/Vista, now it quit. Epson just keeps running me in circles. Uninstall,reinstall etc etc. Printer works, scanner doesn't. Until one day someone suggested that I try VueScan software. I figured it was a sales pitch, but I tried it and it worked. Unfortunatley it cost 39.95 and the Free trial version download only gives you one scan and then the pics/documents are blue with dollar signs. What it did tell me though was that it was the software,not the drivers or anything else. So I've written Epson twice since and asked for help and they have not written me back. I tried again tonight and we'll see?? You might want to download the trial just to see if that is your problem also. Mo
Hp scanner won't work on vista Vista hardware & devices
scanner won't work Vista print fax & scan
Scanner will not work Vista print fax & scan
Scanner does not work Vista installation & setup
Scanner does not work Vista General
