Removing System Tray icons!
  1. #1
    Vista Ultimate
    Local Time: 12:46 AM
    Does anybody know where I should go/edit in order to remove undesirable system tray icons (those beside the clock)? Probably some registry entries or .ini files? How about Group Policies? Any tips? I wouldn't like to install any tweak progs. Thanx everybody!
  2. #2
    Bruce Chambers Guest
    Re: Removing System Tray icons!
    In most cases, with "well-mannered" applications, it's usually as
    simple as opening the undesired program and deselecting the option to
    "display icon in the system tray" or to "start when Windows starts."
    Additionally, Look in the C:\Program Data\Microsoft\Windows\Start
    Menu\Programs\Start Up, and in the system registry, primarily in the
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run and
    HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run keys.
    The following article refers to WinXP, but the same techniques apply to
    Vista:
    How to Troubleshoot By Using the Msconfig Utility in Windows XP
    http://support.microsoft.com/default...b;EN-US;310560
    Bruce Chambers
    Help us help you:
    http://dts-l.org/goodpost.htm
    http://www.catb.org/~esr/faqs/smart-questions.html
    They that can give up essential liberty to obtain a little temporary
    safety deserve neither liberty nor safety. -Benjamin Franklin
    Many people would rather die than think; in fact, most do. -Bertrand Russell
  3. #3
    Ken Blake, MVP Guest
    On Sat, 30 Jun 2007 13:26:58 -0500, beto666
    First, note that you should be concerned with *all* programs that
    start automatically, not just with those that go into the tray. Not
    all autostarting programs manifest themselves by an icon in the tray.
    On each program you don't want to start automatically, check its
    Options to see if it has the choice not to start (make sure you
    actually choose the option not to run it, not just a "don't show icon"
    option). Many can easily and best be stopped that way. If that doesn't
    work, run MSCONFIG from the Start | Run line, and on the Startup tab,
    uncheck the programs you don't want to start automatically.
    However, if I were you, I wouldn't do this just for the purpose of
    running the minimum number of programs. Despite what many people tell
    you, you should be concerned, not with how *many* of these programs
    you run, but *which*. Some of them can hurt performance severely, but
    others have no effect on performance.
    Don't just stop programs from running willy-nilly. What you should do
    is determine what each program is, what its value is to you, and what
    the cost in performance is of its running all the time. You can get
    more information about these at
    http://castlecops.com/StartupList.html. If you can't find it there,
    try google searches and ask about specifics here.
    Once you have that information, you can make an intelligent informed
    decision about what you want to keep and what you want to get rid of.
    Ken Blake, Microsoft MVP Windows - Shell/User
    Please Reply to the Newsgroup
  4. #4
    Vista Ultimate
      Thread Starter
    Thank you guys. The thing is, I don't want to stop programs which start with Vista, but only to stop their icons from being displayed in the Sys Tray, that's all. It should clean things up a bit, and help with startup performance. For example, I don't have any icons on my desktop being displayed. Icons are loaded just like anything else. I want to trim things a bit here and there to gain speed. Thanks for your time. Checking the links and tips.
  5. #5
    Richard Urban Guest
    The icon showing in the notification area is not what slows down your
    computer. It is the running program that places the icon in the tray. Stop
    the program from running at startup and the icon (which cause no system
    delay) will be gone.
    Removing the icon from the notification tray does nothing to speed up your
    computer, if the program that places it there is still running. The icon is
    "mostly" for convenience to you, the user.
    Regards,
    Richard Urban
    "beto666" <beto666.2t0erw@no-mx.forums.net> wrote in message
    news:beto666.2t0erw@no-mx.forums.net...
    > beto666
  6. #6
    On Sat, 30 Jun 2007 16:02:03 -0500, beto666
    > Tray, that's all.
    You have no control over that. Whether they do or not depends on how
    they are coded.
    > performance.
    It will not help with any kind of performance.
    > displayed.
    If you like it that way, that's fine, but you are gaining *nothing* in
    performance by doing it.
    Once again, there is *no* speed to be gained by doing things like
    this.
  7. #7
    Cal Bear '66 Guest
    Won't give you any speed, but you can hide them. Right click Start Orb, select
    Properties, Notification Area tab, Hide inactive icons check box and Customize
    button, highlight the icon you are concerned with and select options from the
    drop down list.
    I Bleed Blue and Gold
    GO BEARS!
    > beto666
  8. #8
    Vista Ultimate
      Thread Starter
    Thanx again everybody. I thought I was doing the right thing, but from your comments I'd rather leave it like it is. Anyway, I removed the starting of some useless stuff (like Quicktime, for instance). The desktop is clean. I tried an SD Card (Kingston) to be activated readyboost, but the system returned not compatible. Will look for something which is.
    All of you were most kind.
  9. #9
    On Sat, 30 Jun 2007 20:02:32 -0500, beto666
    > something which is.
    You're welcome. Glad to help.
  10. #10
    Bob Newmam Guest
    I don't have any objection to most of those programs running, what I do have
    an objection to is being forced to have icons telling me things like "I'm
    currently connected to a local access network", "Microsoft Office Outlook",
    "McAfee Security Center", etc., etc, taking up my valuable tray real estate.
    When I need to click an icon there that I need I can't find it in the mess.
    Then should have an icon for a "drawer" you could puts selected icons in and
    you could open the drawer on an as needed basis.
    Bob
    "Ken Blake, MVP" <kblake@this.is.am.invalid.domain> wrote in message
    news:ksfd839qvginhrmtv34ln36pevgqf0ande@4ax.com...
Page 1 of 3 123 LastLast
system tray icons hello2007 General Discussion 3 11 Feb 2010
Solved System Tray Icons oreo27 Software 5 05 Jul 2009
Remove icons in system tray FPS Vista General 2 13 Jul 2008
System tray icons Steve Vista General 7 31 Jan 2008
System Tray Windows Icons =?Utf-8?B?ZmlUeg==?= Vista General 5 10 Sep 2006
