Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Show more than 3 Power Plans ?
Old 07-12-2007   #1 (permalink)
Michael Tissington
When I click on the battery/power icon in the system tray, I get a list of 3
power plans.
If I go into Power Manager, I have more than 3 plans available.
How can I get the system tray Power icon to display more than 3 plans ?
Old 07-13-2007   #2 (permalink)
Bob J
RE: Show more than 3 Power Plans ?
The 3 power setting are all that are programed > select "Custom" to setup one
of your own settings.
Regards
Bob J
> power plans.
Old 07-13-2007   #3 (permalink)
Bob J
Unfortunately what you see is all preset and can not be changed.
I did not read your post correctly,sorry.
Regards
Bob J
> power plans.
Power plans help please?? General Discussion
power plans Vista General
Changing Power Plans Vista General
vista power plans Vista General
Power Plans Vista performance & maintenance
