| | removable device / ready boost issue I have a 16MB memory stick I initially inserted in the built in reader in my desktop. I removed it and inserted a 1G stick and looked at the Ready Boost tab under properties. It still shows 16MB. I have deleted the device in Device Manger and scanned for new hardware. It isntalls the reader jsut fine but no matter what I do it still shows 16MB and therefore precludes the use of ReadyBoost. Any ideas welcome. |
| | Re: removable device / ready boost issue "16MB" are you sure? Requirement for ReadyBoost external storage reuires a capacity between 256 MB and 4 GB. All devices will not function a a ReadyBoost deivice. Windows, vis properties option, will test the device and state whether or not it is suitable. If device is OK - there is a "slider" made avialble (propertied) by which you can set the space to reserve for ReadyBoost. "Wonderman" <nospamidainc@cox.net> wrote in message news:eK2C3FkxHHA.3364@TK2MSFTNGP02.phx.gbl... >I have a 16MB memory stick I initially inserted in the built in reader in >my desktop. I removed it and inserted a 1G stick and looked at the Ready >Boost tab under properties. It still shows 16MB. > > I have deleted the device in Device Manger and scanned for new hardware. > It isntalls the reader jsut fine but no matter what I do it still shows > 16MB and therefore precludes the use of ReadyBoost. Any ideas welcome. |
| | Re: removable device / ready boost issue I had initially put in an old stick that was a 16 not intending to use ot for ReadyBoost obviously. But Vista is still stuck showng that as the capacity for RB. Any way to reset ? "AJR" <ajrjdr@comcast.net> wrote in message news:uiG6YclxHHA.5068@TK2MSFTNGP05.phx.gbl... > "16MB" are you sure? Requirement for ReadyBoost external storage reuires > a capacity between 256 MB and 4 GB. > > All devices will not function a a ReadyBoost deivice. Windows, vis > properties option, will test the device and state whether or not it is > suitable. > > If device is OK - there is a "slider" made avialble (propertied) by which > you can set the space to reserve for ReadyBoost. > > "Wonderman" <nospamidainc@cox.net> wrote in message > news:eK2C3FkxHHA.3364@TK2MSFTNGP02.phx.gbl... >>I have a 16MB memory stick I initially inserted in the built in reader in >>my desktop. I removed it and inserted a 1G stick and looked at the Ready >>Boost tab under properties. It still shows 16MB. >> >> I have deleted the device in Device Manger and scanned for new hardware. >> It isntalls the reader jsut fine but no matter what I do it still shows >> 16MB and therefore precludes the use of ReadyBoost. Any ideas welcome. > > |
| | Re: removable device / ready boost issue You have not indicated that Windows has stated the new device is capable of being used for ReadBoost. Right click the device - select properties - select ReadyBoost tab - if Windows has okayed use of the device There will be a "slider"s to set the memory for ReadyBoost use. Regarding "...not intending to use ot for ReadyBoost obviously....". Selection for readyBoost is not automatic - you must tell Windows to do so "Wonderman" <nospamidainc@cox.net> wrote in message news:eI45iymxHHA.4652@TK2MSFTNGP05.phx.gbl... >I had initially put in an old stick that was a 16 not intending to use ot >for ReadyBoost obviously. But Vista is still stuck showng that as the >capacity for RB. > > Any way to reset ? > > > > "AJR" <ajrjdr@comcast.net> wrote in message > news:uiG6YclxHHA.5068@TK2MSFTNGP05.phx.gbl... >> "16MB" are you sure? Requirement for ReadyBoost external storage reuires >> a capacity between 256 MB and 4 GB. >> >> All devices will not function a a ReadyBoost deivice. Windows, vis >> properties option, will test the device and state whether or not it is >> suitable. >> >> If device is OK - there is a "slider" made avialble (propertied) by >> which you can set the space to reserve for ReadyBoost. >> >> "Wonderman" <nospamidainc@cox.net> wrote in message >> news:eK2C3FkxHHA.3364@TK2MSFTNGP02.phx.gbl... >>>I have a 16MB memory stick I initially inserted in the built in reader in >>>my desktop. I removed it and inserted a 1G stick and looked at the Ready >>>Boost tab under properties. It still shows 16MB. >>> >>> I have deleted the device in Device Manger and scanned for new hardware. >>> It isntalls the reader jsut fine but no matter what I do it still shows >>> 16MB and therefore precludes the use of ReadyBoost. Any ideas welcome. >> >> > > |
| | Re: removable device / ready boost issue Check Device Manager and delete the 16 gig stick. "Wonderman" <nospamidainc@cox.net> wrote in message news:eI45iymxHHA.4652@TK2MSFTNGP05.phx.gbl... >I had initially put in an old stick that was a 16 not intending to use ot >for ReadyBoost obviously. But Vista is still stuck showng that as the >capacity for RB. > > Any way to reset ? > > > > "AJR" <ajrjdr@comcast.net> wrote in message > news:uiG6YclxHHA.5068@TK2MSFTNGP05.phx.gbl... >> "16MB" are you sure? Requirement for ReadyBoost external storage reuires >> a capacity between 256 MB and 4 GB. >> >> All devices will not function a a ReadyBoost deivice. Windows, vis >> properties option, will test the device and state whether or not it is >> suitable. >> >> If device is OK - there is a "slider" made avialble (propertied) by >> which you can set the space to reserve for ReadyBoost. >> >> "Wonderman" <nospamidainc@cox.net> wrote in message >> news:eK2C3FkxHHA.3364@TK2MSFTNGP02.phx.gbl... >>>I have a 16MB memory stick I initially inserted in the built in reader in >>>my desktop. I removed it and inserted a 1G stick and looked at the Ready >>>Boost tab under properties. It still shows 16MB. >>> >>> I have deleted the device in Device Manger and scanned for new hardware. >>> It isntalls the reader jsut fine but no matter what I do it still shows >>> 16MB and therefore precludes the use of ReadyBoost. Any ideas welcome. >> >> > > |
| | #6 (permalink) |
| | Re: removable device / ready boost issue Spiriit - from his original,post "...I have deleted the device in Device Manger ..." "Spirit" <noone@notthere.net> wrote in message news:OFB5P3oxHHA.5804@TK2MSFTNGP02.phx.gbl... > Check Device Manager and delete the 16 gig stick. > > "Wonderman" <nospamidainc@cox.net> wrote in message > news:eI45iymxHHA.4652@TK2MSFTNGP05.phx.gbl... >>I had initially put in an old stick that was a 16 not intending to use ot >>for ReadyBoost obviously. But Vista is still stuck showng that as the >>capacity for RB. >> >> Any way to reset ? >> >> >> >> "AJR" <ajrjdr@comcast.net> wrote in message >> news:uiG6YclxHHA.5068@TK2MSFTNGP05.phx.gbl... >>> "16MB" are you sure? Requirement for ReadyBoost external storage >>> reuires a capacity between 256 MB and 4 GB. >>> >>> All devices will not function a a ReadyBoost deivice. Windows, vis >>> properties option, will test the device and state whether or not it is >>> suitable. >>> >>> If device is OK - there is a "slider" made avialble (propertied) by >>> which you can set the space to reserve for ReadyBoost. >>> >>> "Wonderman" <nospamidainc@cox.net> wrote in message >>> news:eK2C3FkxHHA.3364@TK2MSFTNGP02.phx.gbl... >>>>I have a 16MB memory stick I initially inserted in the built in reader >>>>in my desktop. I removed it and inserted a 1G stick and looked at the >>>>Ready Boost tab under properties. It still shows 16MB. >>>> >>>> I have deleted the device in Device Manger and scanned for new >>>> hardware. It isntalls the reader jsut fine but no matter what I do it >>>> still shows 16MB and therefore precludes the use of ReadyBoost. Any >>>> ideas welcome. >>> >>> >> >> > |
| Ready Boost Issue | Vista General | |||
| Ready Boost Was Working But Now it Says My Device is too slow??? | Vista General | |||
| i need help with ready boost | Vista security | |||
| Boot failure with Ready Boost Device installed | Vista hardware & devices | |||
| Ready Boost | Vista General | |||
