Desktop Icons - Help Required
  1. #1
    Michael H Guest
    I was using the computer, and recieved a fatal error message on the screen,
    the computer appeared stable but I rebooted to be safe.
    Before I rebooted I noticed that all my shortcut icons (not system icons
    (MyComputer etc)) the desktop items looked like missing target icons.
    After the reboot they still appeared like missing target icons, all other
    icons appear fine, so I deleted the icons of the desktop and created new ones
    (Send to Desktop (Create shortcut)), and the new icons remained the same.
    Now I've only had the laptop a week, so I'm clicking on this and that try to
    get them back, and found that if I change the size of the icons, the original
    icons are displayed but the missing link icon remains but at the original
    size, and upon changing back to the normal size I've noticed the original
    icon is there but is covered by the missing link icon.
    I've copied the icons of the desktop into MyDocuments and the icons are
    displayed correctly, copy them back still a problem.
    Looking in the Desktop Folder in Users, the icons are fine.
    I've deleted the IconCache file, Rebooted problem remains.
    I've changed the colour depth to 16 bit, and the icons are displayed
    correctly take it back to 32bit and the problem comes back.
    I've used system restore.
    I belive it's something simple but what??, Any Help.
    Mike
  2. #2
    Spirit Guest
    Re: Desktop Icons - Help Required
    Check for updated drivers at your System Maker/Motherboard Maker and Video
    Card
    Maker's Sites....
    If no joy then use your warranty.......
    "Michael H" <Michael H@discussions.microsoft.com> wrote in message
    news:1F5E6556-4371-4ECF-A311-8536FF3EB19E@microsoft.com...
    > ones
    > to
    > original
    > Mike
Desktop Icons - Help Required problems?
How do I make desktop icons go away from desktop toolbar in Vista? gtghip General Discussion 7 30 Jan 2010
Double clicking required on more icons than should be Stewie Vista hardware & devices 3 04 Jun 2008
desktop icons covered by unknown program icons maskintoojay Vista General 4 24 Oct 2007
User Icons--Are they required? nashville Vista General 1 17 Oct 2007
login control off - password required after Remote Desktop session speedbump49 Vista security 1 09 Aug 2007
