Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - small black box with blue frame stuck on screen
Old 07-16-2007   #1 (permalink)
Silverlining
Hi...I could use help in removing a small black box surrounded by a thin blue
frame on the right top corner of my screen. It's in front of everything and
can't be moved. It just recently showed up on my new Microsoft Vista Home
Premium program.
Much appreciation for any help.
Old 07-16-2007   #2 (permalink)
dean-dean
Re: small black box with blue frame stuck on screen
You could try this:
The Windows desktop may stop updating correctly after a Windows Vista-based
computer has been running for an extended period of time:
http://support.microsoft.com/?kbid=932406
"Silverlining" <Silverlining@discussions.microsoft.com> wrote in message
news:C07638D2-C45D-4877-BAA6-FB5D067264F5@microsoft.com...
> blue
> and
> Premium program.
Old 07-16-2007   #3 (permalink)
Spirit
Can you right click on it?
Use TASK MANAGER and MSCONFIG to figure out what it is.
http://articles.techrepublic.com.com...1-6161050.html
Task Manager Ctrl - Shift - Esc is direct to it or Cntrl - Alt - Del -
select Task Manager
http://www.vistamania.org/index.php?...=545&Itemid=36
MSCONFIG
> blue
> and
> Premium program.
Old 07-18-2007   #4 (permalink)
Silverlining
RE: small black box with blue frame stuck on screen
I figured out that the black box was the window that could play a TV program
or video while working on the computer. I was able to delete it by going to
the menu. Thanks for the feedback!
....Silverling
> Premium program.
Black frame around screen Graphic cards
Vista stuck with black screen with only mouse cursor General Discussion
Vista 64 Ultimate - Blue Screen then - Boots to Black Screen Vista General
small black line on screen after install Vista General
boot stuck on black screen with cursor pointer Vista installation & setup
