start up problems
  1. #1
    tru_luv Guest
    start up problems
    hi..every time i start up my computer,it will make it as far as my login
    password then shut down automatically and restart.. it will keep doing this
    until i interrupt it while it starts so that i can manually start the
    computer at the last successful login in point.ive read that viruses have the
    same effect but ive recently installed an antivirus program. is there a way
    to fix this? much appreciated..
    theresa
  2. #2
    Rick Rogers Guest
    Re: start up problems
    Hi Theresa,
    Were you trying to install something prior to this happening?
    Have you tried running System Restore to rollback the system to a prior
    state?
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    My thoughts http://rick-mvp.blogspot.com
    "tru_luv" <tru_luv@discussions.microsoft.com> wrote in message
    news:6823035C-269B-4016-8354-58BA16B169DD@microsoft.com...
    > this
    > the
    > way
    > theresa
start up problems problems?
Problems at Start-up Jhm89110 Crashes and Debugging 16 08 Apr 2010
freezing problems & start up problems CindyRB8603 Vista performance & maintenance 0 19 Mar 2010
Start-up problems TelefonHonda General Discussion 2 12 Jan 2009
laptop start up problems and problems in general ryen2324 General Discussion 24 06 Jan 2009
Weirdest problems.Can't start programs from start menu and use Cop Mihai Vista General 1 12 May 2007
