Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - Vista-Java problem
Old 07-25-2007   #1 (permalink)
Kathie G
Guest
Vista-Java problem
Don't know if this is the right place to ask, but I'll try it.
DH got a new laptop about 2 months ago. It came with Vista Home
Premium on it. (Not that we had any choice about that.)
He has a program that he uses in his engineering work with
thermodynamics. The program loads fine, but one portion of the
program (the part that takes the data inputs and does the
calculations) won't work. It needs Java.
(The program is: TEST: The Expert System for Thermodynamics. It can
be run over the internet -- but there are times when he has no
internet connection and needs to be able to run it from his computer
alone.)
He's downloaded the latest Java from Sun several times -- but when he
goes to the page where you verify that the Java is present on your
computer, it never verifies. And, thusly, won't let TEST run.
This is extremely frustrating to him (and to me -- who has to listen
to him rant and rave...).
Anyone have any idea of what is happening here? How we can fix it?
Where we can find someone who can help???
Kathie G
Old 07-26-2007   #2 (permalink)
dean-dean
Guest
Re: Vista-Java problem
In Control Panel > Java, on the Advanced tab, expand "Default Java for
browsers" Make sure the choice(s) have a checkmark. In IE7 > Tools >
Internet Options, on the Advanced tab, make sure the entry under "Java
(Sun)" has a checkmark. Also check IE7 > Tools > Manage Add-ons >Enable
or Disable Add-ons to make sure all Sun Microsystems, Inc. (add the
Publisher column to see these) entries are enabled.
"Kathie G" <Bookwyrm@comcast.net> wrote in message
news:epGFV%23uzHHA.2484@TK2MSFTNGP06.phx.gbl...
> DH got a new laptop about 2 months ago. It came with Vista Home Premium on
> He has a program that he uses in his engineering work with thermodynamics.
> The program loads fine, but one portion of the program (the part that
> takes the data inputs and does the calculations) won't work. It needs
> Java.
> (The program is: TEST: The Expert System for Thermodynamics. It can be
> run over the internet -- but there are times when he has no internet
> connection and needs to be able to run it from his computer alone.)
> He's downloaded the latest Java from Sun several times -- but when he goes
> to the page where you verify that the Java is present on your computer, it
> This is extremely frustrating to him (and to me -- who has to listen to
> Kathie G
Old 07-26-2007   #3 (permalink)
Bookwyrm
Guest
> thermodynamics. The program loads fine, but one portion of the program
> (the part that takes the data inputs and does the calculations) won't
> Kathie G
I printed out dean-dean's answer and then accidentally deleted it. Rats!
But, did as he suggested. Sorry, but it didn't work.
Any other ideas what's wrong? Active X won't work either.
K.
updating java problem Vista General
Vista crashes firefox every time I try to use del.icio.us firefoxextension - is this a java problem? Vista General
Problem with Tomcat server on windows Vista when used with c++ and java Vista General
Microsoft Java? Is it available in Vista? (not sun java!) Vista General
