Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Fan goes crazy after waking from sleep
Old 08-06-2007   #1 (permalink)
HrundiBakshi
Running the latest and greatest Ultimate x64 Vista on the latest and greatest
cutting edge gear (single Woodcrest on a Tyan S2696 board, 4G of RAM).
Whenever I wake the computer from sleep, the CPU fan goes crazy (upwards of
4500rpm) trying to keep the CPU temperature under 25C (or thereabouts). I
have to reboot in order to get the fan settle at fixed 2000rpm. CPU
temperature is, under average use, not higher than 40C. Note also that I have
not toyed with the Power Plan: everything in this respect is at the Windows
default values and profiles.
Keeps waking from sleep Vista General
Waking from sleep Vista General
Sleep/waking up Vista General
waking up from sleep Vista General
