Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - Customize Vista's System Restore?
Old 08-06-2007   #11 (permalink)
Bert Kinney
Guest
Re: Customize Vista's System Restore?
Hi Phillip,
How to adjust disk space in Windows Vista:
http://bertk.mvps.org/html/diskspacev.html
Regards,
Bert Kinney MS-MVP Shell/User
Member: http://dts-l.org
Phillip Pi wrote:
> In Windows XP, I could customize each drive to have a non-default size
> (low as 200 MB), disable, or enable for the system restore feature. In
> Vista, I cannot customize each drive. I can only enable and disable it.
> Did I miss this option in Vista?
> Thank you in advance.
Old 08-07-2007   #12 (permalink)
marcusFZ6
Guest
Dudes, I have just read this and completed the nessecary steps. I asked a q
in filling 30GB of space only to find that 14GB was restore points, see post
"FILLED 30GB of SPACE".
Think that this is a very handy tip and worth knocking the size down a fair
bit. Top drawer stuff.
Cheerz, Marcus
Old 08-08-2007   #13 (permalink)
Bert Kinney
Guest
You're welcome Marcus.
Regards,
> Cheerz, Marcus
Customize System Restore intervals Vista General
Vista's System Restore points format. Vista General
Customize Vista's System Restore? Vista General
Customize Vista's System Restore? Vista file management
How good is Vista's System Restore Vista performance & maintenance
