Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Customize Vista's System Restore?
LinkBack Thread Tools Display Modes
Old 08-06-2007   #1 (permalink)
Phillip Pi
Guest
In Windows XP, I could customize each drive to have a non-default size
(low as 200 MB), disable, or enable for the system restore feature. In
Vista, I cannot customize each drive. I can only enable and disable it.
Did I miss this option in Vista?
Thank you in advance.
Phillip Pi
Senior Software Quality Assurance Analyst
ISP/Symantec Online Services, Consumer Business Unit
Symantec Corporation
www.symantec.com
Email: phillip_pi@symantec.comSYMC (remove SYMC to reply by e-mail)
Please do NOT e-mail me for technical support. DISCLAIMER: The views
expressed in this posting are mine, and do not necessarily reflect the
views of my employer. Thank you.
Old 08-06-2007   #2 (permalink)
Jon
Guest
Re: Customize Vista's System Restore?
"Phillip Pi" <phillip_pi@symantec.comSYMC> wrote in message
news:uS5XeKG2HHA.1184@TK2MSFTNGP04.phx.gbl...
> Phillip Pi
> www.symantec.com
There's this option at the command line, although how well it works I don't
know
vssadmin resize shadowstorage /?
I recall a thread a while back where it was suggested that it doesn't work
as intended, due to a bug (?). May be worth a try though. Let us know if it
does the trick.
Jon
Old 08-06-2007   #3 (permalink)
Michael Solomon
Guest
> Phillip Pi
> www.symantec.com
Did you try using System Restore to take you
back to a time prior to when this began. While System Restore is meant to
only restore your settings and registry to a specific point in time, as a
precaution, your data should be well backed up before using it. Start
Menu\Programs\Accessories\System Tools\System Restore.
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Old 08-06-2007   #4 (permalink)
Lord Takyon
Guest
"Jon" <Email_Address@SomewhereOrOther.com> wrote in message
news:uXeM7SG2HHA.4004@TK2MSFTNGP05.phx.gbl...
>> Phillip Pi
>> www.symantec.com
> don't know
> it does the trick.
> Jon
It ha worked fine on the 4 machines I have done it so far. The only thing I
did notice was that it did not take first time on one of the machines. This
had to be done on these machines because system restore was using up to 50%
of the HDD. I set it to 5 Gig on each machine.
Can't think of a sig at the moment.
Read this instead.
Old 08-06-2007   #5 (permalink)
Phillip Pi
Guest
Umm, I am not restoring anything. I just want to customize it. Please
reread what I typed.
Phillip Pi
www.symantec.com
Old 08-06-2007   #6 (permalink)
Michael Solomon
Guest
news:#ZBSaAH2HHA.1100@TK2MSFTNGP06.phx.gbl...
>> to
> Phillip Pi
> www.symantec.com
I'm sorry, Phillip, I think that was meant for a different thread and
somehow I accidentally posted it in this one.
Michael Solomon
Old 08-06-2007   #7 (permalink)
Wayne L
Guest
Phillip - There is a MS site for reducing System Restore. Do a Google search,
or go to "howtogeek.com" home page. I've used his advice and it works. Wayne
Wayne L
> >> to
> > Phillip Pi
> > www.symantec.com
> Michael Solomon
Old 08-06-2007   #8 (permalink)
Phillip Pi
Guest
>>>> size (low as 200 MB), disable, or enable for the system restore
>>>> feature. In Vista, I cannot customize each drive. I can only enable
>>>> and disable it.
>>> meant to
>>> as a
Thanks for the reply. Misreplying happens (I have done it before).
Phillip Pi
www.symantec.com
Old 08-06-2007   #9 (permalink)
Phillip Pi
Guest
Thank you.
Phillip Pi
www.symantec.com
Old 08-06-2007   #10 (permalink)
Phillip Pi
Guest
http://lifehacker.com/software/windo...age-254365.php
for anyone who cares. I wonder why MS disabled this. I think it is a big
waste to have GBs of system restore points if I had an one TB drive
(153.6 GB used for system restore points) or something. :/
Phillip Pi
www.symantec.com
Display Modes
Customize System Restore intervals jimb11 via WindowsKB.com Vista General 1 04-25-2008 10:49 AM
Vista's System Restore points format. Carl Farrington Vista General 6 11-24-2007 11:26 AM
Customize Vista's System Restore? Phillip Pi Vista General 14 08-08-2007 01:02 PM
Customize Vista's System Restore? Phillip Pi Vista file management 12 08-08-2007 01:02 PM
How good is Vista's System Restore Alan Robinson Vista performance & maintenance 19 04-22-2007 12:41 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
